Question about Car Audio & Video
I have a ford expedition the radio works only for a little while after you turn the truck on, everthing works fine and then it display PHONE , then it has no sound and none of the buttons will work it just freezes up and it shows PHONE it is a factory stereo in a 1999 ford expedition eddie bauer 4x4
  • 6,784 Answers
HI. I have an expedition of the same make and model. unfortunately, this issue with the radio is a common issue with this actual stereo package. The logic chip that controls all functions of the affected stereo, in your case, has failed. This will occur repeatedly when the stereo temperature reaches normal operating status. It is a basic cold solder break that has separated the logic chip from its seated position on the micro board.
The only option for me in this case was to replace the entire stereo system in my expedition. I was unable to repair the damage, due to the fact that the board is not replaceable. Ford will re-issue the same stereo for a small fee, if the vehicle is under an extended warranty package that covers all electronics. If you do not have this warranty package, you will be responsible for the total replacement cost of this defective stereo system. You will only need to replace the in dash stereo, and not the speakers or any other attached accessories.
Posted on May 11, 2010
The light on may 2000 ford expedition radio went out . how do I find the fuse ?
if the radio works, then it isn't the fuse in my view, it is the display bulb or LED.
See this for the fix.
Radio display not working 2000 Explorer Ford Truck Enthusiasts Forums
Nov 07, 2017 | Ford Cars & Trucks
My 2000 Ford Expedition trying to start on it's own The little wire on the solenoid comes on and off when you hook a test light to it when the key is on the on position therefore if it was plugged into the...
Try checking out the PRNDL switch (neutral safety)on the tranny . Pull out the plug where the shifter cable linkage is and then check that signal wire at the starter for power . If it has no power with the switch unplugged you found your problem . Shorted neutral safety switch .Seen it many times on FORD .
Feb 25, 2015 | 2000 Ford Expedition
2003 Ford Expedition battery died and when restarted, the radio won't work
I think your radio is much like the one in a Taurus, and mine has had hiccups like that before. First locate the actual radio which is in the back somewhere behind a cover. Unplug it and wait a few minutes to be sure it is reset. Plug it back in and it should work fine again. This may also fix your navigation system, if it doesn't find the 'brain' of the navigation thing and unplug, wait a few minutes, then plug it back in.
May 27, 2014 | 2003 Ford Expedition
Dash lights
check main power supply fuse
Aug 21, 2013 | 1999 Ford Expedition
My wife was driving our 2001 expedition. Turned a corner and the the truck shut off. It will turn over but will not start. No codes are displayed when checking it with a reader. When key is in the on...
have you checked to see if its firing at the plugs. if not you may want to have the control module tested. start there and work back to battery. including any wires to starter and also the crank sensor.
Jan 17, 2011 | 2001 Ford Expedition
1999 FORD EXPEDITION intermittantly will not start.
You have a bad starter. A faulty starter will function when its cold but when it heats up, it takes more energy to get the starter to engage. Your problem is exhibiting the classic symptoms of a bad starter. I hope this solves your problem and the best of luck to you.
May 11, 2009 | 1999 Ford Expedition
2000 Ford Expedition, power windows and dome lights won't come on
first of all you may not be looking for a fuse if you have an owner manual check the fuse box under the hood as well it maybe one of the little boxes called a relay
Jan 02, 2009 | 2000 Ford Expedition
2005 Ford Expedition stopped working yesterday
take to dealer think its the gem module will need to be programed after new is installed
Dec 10, 2008 | 2005 Ford Expedition
99 ford expedition radio problem
This is not a fuse problem, it is a burnt out display backlight bulb, you have to pull the radio out of the dash and remove the top cover of the radio, you will see a tiny bulb socket, twist it out, replace that little bulb.
Oct 13, 2008 | 1999 Ford Expedition
2003 Ford Expedition radio will not work
phone any ford dealer and with your vin# handy give it to the service manager and they should be able to get that for you.
May 26, 2008 | 2003 Ford Expedition
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
