Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Turned on tv with remote (this turns on cable box and tv). TV came on for a few seconds and then went off, no picture, no sound. Remote would still change channels on cable box, so it is obviously the tv. It is a Panasonic HD projection tv. Any advice?
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Most of these have a shutdown feature built in and if you unplug the set, plug it back in and turn it on manually look carefully at the power light on the front when you turn the set OFF.
It should blink a specific sequence: 3 blinks, a pause and 3 blinks etc.
3,3 and 5,5 are the most common and mean different things are wrong.
Let me know if you are able to see the error code.
SD TECH
Posted on May 12, 2010
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
Bought 2 DTT-9900 converter boxes and hooked them to 2 TV's, get signals after playing around with antenna. but after using both TV's to play a dvd (dvd player hook to TV) The sound went down to almost...
Try turning off the converter box when using the DVD player. The zenith have a second sound control on the converter box remote thus you may have to adjust the sound on the tv remote because you are using the dvr. I set the zenith sound level at the highest level and use on the tv remote only to adjust sound. This eliminated a hiss that the sound control on the converter box was causing.
Apr 28, 2008 | Zenith ZN110 Remote Control
PIP
Look for a "PIP" (Picture In Picture) button on the remote or in the TV's menu. I suspect that it has been pushed but there is not a second source to view. That would explain the smaller version in the corner.
Apr 08, 2008 | Vizio GV42L 42 in. LCD Television
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
