Question about Logitech Harmony 890 LCD Remote Control
Remote control is slow to react, or does not work at all
At times it seems to respond in slow motion, but sometimes I try to change the channel and it does not react at all.
  • aschonh May 11, 2010
    I have a Harmony 550 and it is very slow in reacting when I push for a channel change. Sometimes it does not work at all. Sometimes it is hard to turn the TV off.
    I have a Harmony 550. How do I get it out of safe mode?
  • 11,896 Answers
Use fresh batteries, clean the front of the sensor with rubbing alcohol and a cotton swab or windex I guess. Do the same on tv and dvd player or whatever device you are using. Just keep the IR Sensors clean.
They also have updates you can get for these remotes as well
Posted on May 11, 2010
  • Nate Stansfield
    Nate Stansfield May 12, 2010
    A software update can get it out of safe mode.
    You enter Safe Mode by removing the batteries and reinstalling them
    while holding the Power button - my guess is that this started when you
    were replacing the batteries. To get out of it, do a firmware update
    from your PC. This will install the latest firmware and your
    configuration. Safe mode is a bootstrap designed to recover from
    firmware corruption issues so about the only thing it knows how to do is
    reload firmware.
    However, if the remote fails to communicate with the PC when it is
    stuck in Safe Mode, please try the following.
    1. Remove
    the batteries from the remote & check for any stuck buttons
    especially the Power button that may be causing the remote to stay in
    this state.
    2. If it still will not apply firmware to get out of
    safe mode, then still without batteries hold down the #2 button while
    plugging into USB, and it should exit Safe Mode, and say something
    similar to 'Firmware Upgrade Success'. Even though it says this,
    still perform the Firmware upgrade since it was stuck in Safe Mode to
    begin with.
    Firmware can be found from your accounts Home
    page, at the top Downloads -> Firmware.
    Safe Mode is a diagnostic tool in the Remote used for troubleshooting
    purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on
    the remote, complete the following steps:
    1. Ensure the Remote is in "Safe Mode Requested" by taking out the
    batteries, and disconnecting the remote from the USB cable.
    2. Hold down the Off button and plug the remote into the USB.
    3. Continue holding down the Off button for another 10 seconds. The
    remote should then display the words "Safe Mode Requested".
    4. With the unit in "Safe Mode Requested", re-install the firmware by
    clicking Support on your home page.
    5. Click Firmware in the Downloads section and follow the online
    instructions to upgrade the firmware.
    6. Once the firmware upgrade is complete, click Update My Remote.
    7. Insert new batteries into the remote.
  • 10,515 Answers
There could be many things that needs to be checked.Let me explain you in details :-
1. First of all, you need to Make sure that there is nothing wrong with the Battery.Used another set of battery.
2. Take a Cotton and Clean the Connectors. I have seen many times, that due to Dust and Dirt, the Battery Connectors might result in Intermittent Working.
3. Last Option, before you could Opt for a New Remote or get it Repaired ( which is not a wise Option as more often you as the cost of repair is high relatively to the cost of the New Remote ) - You could Dissemble the Remote and Clean the Pads. Clean the Sensor and make sure that there is no Circuitry Fault.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • 2 more comments
  • taran_2005
    taran_2005 May 11, 2010
    Thanks for your response!!
    You could Try the above 3 Methods. If that would not work, you need to replace the Remote.
    Hope i helped you.
    Thanks
  • taran_2005
    I am Surprised, is this another Question ???
    Initially you never mentioned that it is in Safe Mode
    Question - At times it seems to respond in slow motion, but sometimes I try to
    It is advisable to mention all Error Messages, and the Problem in Detail.
    Have You tried to Update the Firmware?
    Let me know,so that i could Proceed.
    Thanks!!
  • aschonh May 12, 2010
    It is now on safe mode. How do I get off of it?
  • taran_2005
    taran_2005 May 12, 2010
    To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
    However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
    1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
    2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
    Hope i helped you.
    Thanks
  • 4,472 Answers
Have you tried changing the battery? Once I have more information I can assist you further.
Thank you,
Lee
  • 7 more comments
    I have put new batteries in twice - does not help
  • Lee A.
    Lee A. May 11, 2010
    this information should help you. It's also been addressed on logitech site:
    Click on the Device's "More Options"
    - Select "Adjust the delays (speed settings)"
    Inter-key Delay: 300ms
    Inter-Device Delay: 300ms
    Start by adjusting the Inter-key and Inter-Device delays to 300ms or
    less. Then test the remote. If it works at 300ms, keep lowering the
    speed in 100ms increments and see if the device still responds. If it
    doesn't, increase it back up 100ms. In my experience, I've found that
    most devices will respond to 100ms and devices like Tivos will take an
    Inter-key of 0ms.
    Click on the Device's "Troubleshoot"
    - Select "Show me more problems"
    - Select "Device doesn't appear to receive every command correctly."
    - Select "The device responds too much to some commands (for example,
    volume up increases the volume too quickly)."
    The default number of repeats is 3. Lower the repeat speed and see if
    the remote still responds. If it doesn't, increase the number of repeats
    until the device still responds. In my experience, most devices will
    respond with 2 or more repeats and devices like Tivos will respond with 1
    repeat.
    If you need further assistance let me know,
    Thank you,
    Lee
    how do I find "more options"?
  • Lee A.
    Lee A. May 11, 2010
    Do you have the 890 or the 890 pro?
    These steps should help you:
    1. Once you have updated your remotes, the display on the remotes will show a welcome greeting; press OK.
    2. Continue pressing OK until you see the start of the Activities menu.
    3. Press System Options.
    4. Press RF Network Tools.
    5. Press --> to view more options.
    Hope this helps.
    Thank you,
    Lee
  • Lee A.
    Lee A. May 11, 2010
  • Lee A.
    Lee A. May 11, 2010
    These are very complex remotes so there are a lot of possibilities to what it could be. Have you updated the firmware at all? Please take a moment to accept/rate my solution as I see you have passed on my assistance.
    Thanks,
    Lee
  • Lee A.
    Lee A. May 11, 2010
    Well then that would be part of the problem. You listed your problem under an 890 remote. Had i been given the correct model number I may have been able to assist you properly sooner.
    Thank you,
    Lee
  • Lee A.
    Lee A. May 11, 2010
    taking the remote apart and cleaning the contacts with at least 91% rubbing alcohol will do the trick. Also be careful to not strip the screws. Please accept/rate my solution as you should find this information more then helpful.
    Thank you,
    Lee
  • Lee A.
    Lee A. May 12, 2010
    If you could accept/rate my solution I would be glad to assist you further. Otherwise it looks like you have asked for another expert to help you.
    Thank you,
    Lee
Non responsive buttons
You have to open up the remote. The underside of each button has a black disk. Clean each button with a pencil eraser. Then look at the circuit board. Where each of the black discs would make contact (looks like two "E"s facing each other) clean each of those with the eraser. But the remote back together and all the buttons will be responsive.
Jan 17, 2014 | Universal Remote Control Universal Remote...
My harmony 700won`t take the numbers when I try to change channels
Check with an other code to your device with the remote control.
Aug 08, 2012 | Logitech Harmony 700 LCD Remote Control
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
PVR9200T very slow to react to remote control
I have 5 customers machines doing the same. rang Humax today. They are working on the fix..and hope to have an OTA update at the end of the month....keep you fingers crossed eh?
Oct 11, 2009 | Humax Televison & Video
Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Sep 19, 2006 | Philips 28PW6506 28" TV
Logitech Harmony 890 LCD Remote Control Logo
279 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
