Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
I need to replace the belt on my hoover fusion plus upright vac. But I cannot find what belt it takes. the number on the belt is worn off
    President:
  • 1,871 Answers
Hello :
1:Unplug your Hoover vacuum. Turn the vacuum up-side-down and place the motor and vacuum portion on a counter top with the handle hanging down toward the floor. This makes it easy to work on the underside of the vacuum portion of the machine.
2:Locate the two plastic release levers near the front wheels of the vacuum. On most machines you will only need to push these levers outward with your thumbs to release the bottom panel of the vacuum. On certain older models, there are two screws that will need to be removed with a screwdriver. Once released, remove the bottom plate.
3:Locate the drive belt. Unless the belt is broken completely, it will be plainly visible. One end of the belt loops around the shaft of the vacuum's motor and the other end wraps around the vacuum's beater bar. The belt is in a modified figure 8. Use your fingers to stretch the belt slightly and remove it from the small shaft of the motor which will be almost dead center under the vacuum.
4:Remove the roller (the beater bar) that is across the front edge of the vacuum. In most models you can remove the bar by simply pushing it forward slightly and then lifting it up out of the U groove that it is held in. In some models you may need to use your screwdriver to push aside two clips that hold the bar in place.
5:Remove the belt (if attached) from the bar and then clean the bar. The bar may have hair and bits of carpet wrapped tightly around it, especially at the ends where the accumulated mess could prevent the bar from spinning freely. Use scissors or a utility knife to carefully clean off all hair and other debris. Make certain that the roller rolls smoothly and easily.
6:Place the new belt around the roller, fitting it into the groove in the middle of the bar. Replace the bar in the machine. In most models, the bar should simply drop down into the U grooves that hold it. Give the belt half a twist (like the figure 8) and then loop the free end around the shaft of the motor.
7:Replace the bottom of the vacuum and push the retaining tabs back in place with your thumbs or screw in the two screws that hold the bottom on. Turn the machine over, plug it in, and it should be working like new.
Things You'll Need: Replacement belt Screwdriver (for some models) Scissors Utility knife
Warning:
1:If your machine makes a screeching noise when you turn it on, then turn it off and unplug it immediately. Turn it over and check to see that the bar is seated properly before turning it back on again.
2:Never work on your vacuum if it is plugged in.
PLEASE RATE !
Posted on May 12, 2010
My hoover fusion carpet brush wont revolve
Hello, I hope your having a good day considering your problem.
It sounds like you have done everything and more you can at your end. My opinion based on your detailed description is that is possible you might need to barrings in your roller on both ends. Now sometimes you can take it to a local vac shop (just the roller of course) and they can put the new barrings in as well as maybe it is possible that something is just loose or warn out. Sometimes you are better (for cost of repair reasons) to buy a new roller. I would first personally, take the roller off, and take in to local shop and have them give you a price to replace or repair. That appears to me what has happened. Its also possible, some dirt and debre has got trapped in where there barrings are and it is sticky or just plan stuck. Mike
Dec 02, 2011 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Is my model nno. US183900 S/N 080600079068 still under warranty? I have a broken hinge post in the bottom cover of the dirt canister. Thank you.
The Hoover Fusion Plus Cyclonic Upright Vacuum has a 1 year manufacturers warranty from date of purchase. You need to check your reciept to see if it's under a year old. Then go to the Hoover.com web site to find the closest Hoover warranty service center to where you live. Bring the proof of purchase and the vacuum to them.
Apr 08, 2010 | Hoover Fusion Plus Cyclonic Upright Vacuum...
No sucksion and the brissels are not spinning
That means that the belt is stretched or broken and needs to be replaced. Here are the belts you need:
Hoover Fusion Belts
Mar 13, 2010 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
Installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Does the Hoover Fusion plus vacumn have a reset button
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=628595
Generic problem for all Vacuums
Posted by bfranklin on May 28, 2008
Does the Hoover Fusion plus vacuum have a reset button
I did a search on the Hoover Fusion and to the best of my knowledge the Hoover Fusion does not have a reset button and it would be my suggestion is that to call the Hover Factory phone # listed below to see if they can answer your question as I could not find the model # for the item you are requesting. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 28, 2008 | Vacuums
Manual
Go to hoover.com, scroll down to downloads, enter your model number which is located on the metal tag either on the back or bottom. If it is available you will be able to download it.
Feb 29, 2008 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
370 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
