Question about Motorola Mobility W370 Cellular Phone
Want to send a picture I took with the phone to an e-mail address. It keeps on failing. I tried a different e-mail address and it failed again. Sometimes in the past it has worked well but at other times it has been a problem. Now I've tried for three days with different pics and it is still not working. Any advice?
  • Motorola Mob... Master
  • 641 Answers
Check the size of the picture..make sure that your service provider is still offering email..other then that make sure that your phone is still setup with the proper information.
Posted on May 13, 2010
Getting error code for sending e mails from Windows Vista home. Ox8OOCCCOD
Third Party Solution Found: From Microsoft
Error 0x800CCC0D
Problem: When you try to send or receive email, you get an error message. It
says the error number is 0x800ccc0D.
Solution: This error is basically saying that your computer cannot connect
to the mail server. The most common and obvious cause of this is that you
are not connected to the internet at all. To test whether this is the case,
try opening a news web page like news.com or doing a Google search (just
opening your homepage is not a good enough test, because it may be saved, or
"cached", on your computer's hard drive). If this test fails, then the
problem is not with e-mail specifically, but rather with the internet
connection. For users on dial-up, you need to dial in first, and then you
should be able to check your email. If Windows is indicating that you are
already connected, try disconnecting and then dial in again. If that fails,
try restarting the computer and then connecting again. If that fails, you
may have spyware or your modem may have gone bad.
If, on the other hand, you are able to pull up web pages, yet still get
error 0x800CCC0D, you should check to make sure the mail servers are typed
in correctly. To check this in Outlook Express, open the Tools menu, select
Accounts, click on the Mail tab, click on the Properties button, then click
on the Servers tab. Or, if you use a different email program, follow the
equivalent procedure for that program. The incoming mail server should be
pop3.vcn.com unless your email address doesn't end with @vcn.com, in which
case put in whatever your address ends with instead of vcn.com (for example,
if your address is person@wavecom.net, enter in pop3.wavecom.net ). The
outgoing mail server should be smtp.vcn.com or substitute whatever your
email address ends with for vcn.com.
Make sure to check the mail servers for all your mail accounts if you have
multiple email addresses.
If you still get error 0x800CCC0D, and definitely can pull up web pages
(that is, the rest of the internet is working fine, only email is having a
problem):
* Restart your computer. This is simple, so you might as well try.
* Try disabling e-mail scanning in your anti-virus program. To do this
in Norton, double-click on the yellow picture for Norton down at the bottom
of your screen by your clock to open Norton. Then click the Options button
at the top of the window (if a drop-down menu appears, choose anti-virus),
then click the word Email on the menu on the left side. Uncheck both Scan
Incoming and Scan Outgoing. Click OK, then close Norton. Try checking your
messages again.
* Disable your firewall. It could be blocking Outlook Express, or
whatever your email program is, from accessing the internet. McAfee firewall
will usually not turn off even when you tell it to, so you'll have to go
into the firewall settings and delete your e-mail program from the blocked
list, or just uninstall McAfee firewall entirely using the Add/Remove
Programs control panel.
* Make sure you recieve replies when you ping the mail server. If you
cannot, something strange is going on.
* Try checking email using a different mail program such as Thunderbird,
or through webmail on our web site, and see if that works.
Other Cases
You may be able to get mail when you first open Outlook Express, but then
get error 0x800CCC0D from then on. To solve this, go to the Tools Menu >
Options > Connection tab, and uncheck "Hang up after sending and receiving".
Your email works fine, but error 0x800CCC0D keeps constantly popping up over
and over. In Microsoft Outlook, Tools > Options > Mail Setup tab > Send and
Receive, and uncheck "Schedule an automatic send/receive every 5 minutes"
(older versions of Outlook will have a similar option under the Mail
Delivery tab). In Outlook Express, go to Tools > Options, and uncheck "check
for messages every ... minutes".
Shenan Stanley
MS-MVP
Quoted and pasted by Jack Isaacs for FixYa
Hope This Helps.
Jack Isaacs
Jan 29, 2010 | Microsoft Windows XP Home Edition
Cannot get or send mail. error ox8oocccod
Error 0x800CCC0D
problem):
messages again.
Other Cases
Aug 30, 2009 | Sony VAIO JS Series Desktop Computer...
Sending photos
you must have MMS configured and on also have MMS activated in card to check this call local operator and ask for configuration, or see your operators webpage.
Aug 03, 2009 | Cell Phones
SMTP Problem
pwningnoobs8 means to try to send to that address FROM a diferent address, to see which address' fault it is.
Also... this may sound funny, but info@mydomain.com isn't the ACTUAL address you're trying to send to right? Plz tell me you just replaced it here for security sake?
Jul 23, 2009 | Microsoft Outlook 2002 Step by Step for PC
My LG Voyager won't recieve or send pictures, videos, or sounds.
i would contact your service provider. this is a network issue and not your phone.
May 22, 2009 | LG VOYAGER VX10000 Cellular Phone
Email
Why do I get a "Failed Delivery" message?
When you get mail from a "MAILER-DAEMON" or a "Mail Delivery Subsystem" with a subject similar to "Failed Delivery," this means that a message you sent was undeliverable and has been "bounced" back to you.
These messages are produced automatically and usually include a reason for the delivery failure.
Bounced messages normally consist of two parts. The first contains the reason for the bounce; the second contains your original message.
The most common reason for a failed delivery is that the email address you entered isn't valid.
If the Mailer Daemon says that the account doesn't exist, double-check the spelling of the address you entered.
A single misplaced letter can be enough to cause a failed delivery. If the message continues to be bounced back to you, you might want to verify that the account hasn't been closed or moved.
If there's a different reason given and you'd like us to investigate it, just let us know.
If you can copy and paste the reason given for the failed delivery into the message you send us, it will be very helpful as we attempt to determine why your message bounced.
Source
Oct 24, 2008 | Yahoo Mail
E MAILS FAIL TO GO
Dear Geoff, There can be multiple reasons for this. When you reply and error shows up it can be:
a) Your internet speed is slow and your email client has not been able to send your message.
b) Check the email address you're sending the email too. Recipient email address can be full.
c) Check your email settings to ensure that your outgoing and incoming mail servers are working.
d) If you are still facing problems maybe you can make new email address on relatively more user friendly websites like Yahoo, Hotmail or Expedia.com.
If thats helpful kindly press solved.
Nov 25, 2007 | Adobe Photoshop 7.0 for PC
E-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Motorola Mobility W370 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
