Question about Cameras
I want to know how to use a 35 mm RICOH TLS 401 camera
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem
Thanks for using FixYa.
Posted on May 19, 2010
  • AliTech110
    AliTech110 May 19, 2010
    You can download the usage instructions in PDF format by clicking this link.
    • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
    Thanks once again.
Pentax K2000 DSLR stopped working after using manual K-mount lenses?
Have a look on Pentax Forums as a guest - you may find something there
Oct 17, 2017 | Pentax Cameras
Can you get a digital back to covert it into digital
Hi.
No. I had never see somethig like a digital back for a film camera like this.
The digital backs made from companies like LEAF and FACE ONE, had only be made for medium format cameras.
Sep 20, 2015 | Ricoh Kr-10m 35 Mm Film Camera / Promaster...
Can't see image through lens
It would seem that the mirror is locked up. Some cameras have a mirror lock to reduce vibration after the view is focused and ready to expose. Check your camera features. If it doesn't have this feature than the camera may need servicing.
Mar 19, 2014 | Ricoh KR-30SP 35mm SLR Camera
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Are there any digital cameras on the market that will allow me to make use of my existing ricoh k mount 35 mm camera lenses? (originally used on a Ricoh KR10
Some pentax digitals(most) will accept k mount lenses. Ricoh differed from the Pentax standard in one slight -- but important -- way. They used a locking pin (called the "Ricoh pin") that just happens to fall at exactly the same place as the auto-focus socket on Pentax auto-focus cameras. (That include Pentax film and digital SLRs with auto focus.) If you put your Ricoh lens on the AF Pentax, you may find that the Ricoh pin will get stuck in the AF hole and you can't get them back apart. The fix is simple, if you are even a little bit handy and have a jewellers' screwdriver. You can remove the pin from the Ricoh lens, and then safely use it on your Pentax cameras. The lack of a pin doesn't seem to adversely affect either the lens or the camera.
For more details, see here:
http://forums.dpreview.com/forums/read.asp?forum=1036&message=19214685
Nov 04, 2010 | Photography
I'm looking for a owners manual for a minolts 3Xi 35 mm
Hi - You can download the manual by clicking the link underlined in blue below:
3Xi 35 mm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 28, 2008 | Cameras
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
