Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Green blinking light tried the reset unplugging pressing the wolume up and channel down button solution TV turn on after 20 seconds went black only audio working and then turned right back off
  • Sharp Master
  • 8,457 Answers
U have sound but no picture?Ur lcd inverter board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 11, 2010
Turn the tv on and the green light blinks and then turns off and comes back on then turns off again but the screen is black. What is wrong?
KDF 60XS955 intermittently turns off green light blinking then on after...
The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight.
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state
ref:
Sharp lcd tv power button flashing
Feb 13, 2016 | Televison & Video
Sharp Aquos TV doesn't work, power light is blinking at 1 blink/sec
Sounds like a fault code, ~I have found some info on it:-
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state.
hope it helps
Aug 23, 2014 | Sharp Aquos Televison & Video
Sharp flat screen, went black. On/off button doesn't work, just flashing white light - help
Jul 28, 2014 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
219 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
