Question about Adobe Audition 1.5
Hi, i have a problem here regarding the subject. when i try to open a mp3 file an error appears and ask me to make it PCM Raw data as file type and do the asterisk thing and try open the file again, i tried and it still doesn't work. Any solution into that?? thanks in advance
  • 5,603 Answers
I don't have the manual for this, however, the program may be INCAPABLE of opening an MP3 file.
One will find that many programs will not open every file type.
OFTEN one will find they have to use the "Import" feature instead of open to accept the file type they have. Often these programs will output a file type or export it in a different format.
So see if they might have an "Import" function.
Posted on May 11, 2010
Data recovery
How to recover "raw" drive data:
When a hard disk drive bracken or loss her partition and if you try open this drive then you got this message "Disk not formatted" .
At the times you should use any "raw" data recover software .
or
use recover "partition damage" software download
recover everything
Nov 05, 2013 | PNY 8GB HP c500w USB Drive
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
My memory card is not opening
Your card may not be formatted -or- it is and it;s a proprietary format. If you want to format it, here is the instructions (for Windows):
Put your card into your computer (some have a slot or else use a card reader). Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
Dec 21, 2011 | Kingston 2GB Secure Digital Memory Card
When I try to import a file into a new session, the sample rate box pops up. I click Ok on 44100, but then another box pops up about but rates and other foreign jargon about PCM and raw data and stuff. I...
This procedure is a common one for the Audition 1.5 when trying to import (or open) an unknown file type. At most of the cases the result of this kind of import is wrong. Could you please clarify me what is the file's extension that you're trying to open in order to guide you to get (for free) the proper import plug-in (the extension has to be like wav, or mp3, or m4a, or mp4 etc)
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 28, 2011 | Adobe Audition 1.5
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
2 GB PENDRIVE SHOWING UNABLE TO FORMAT. AND ASLO
You can try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 07, 2010 | Transcend (589307) Media
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
ERROR ! EXITING TALLY!
Error! Exiting Tally! File Name C:\tally\data\004\Tr01320.500 Size 196608 Position 196608 Chars 128 (Done 0).
Apr 21, 2009 | Computers & Internet
Raw file system
To fix the problem
Disable the S.M.A.R.T error detection feature in the CPUCool program or similar utility.
Boot to the Windows 2000 or XP installation CD, and at the Startup menu, press R for repair.
In the Recovery Console, type the following:
chkdsk /p
When the CHKDSK process has finished, reboot the computer.
Run the program again.
The error should no longer be reported unless you start using the S.M.A.R.T error detection feature again.
Error occurs with PartitionMagic 8.0
If you encounter Error 1516 with PartitionMagic 8, first run CHKDSK /F on the affected partition. For instructions on how to run CHKDSK, read How to Run Microsoft's CHKDSK from the Command Line. If this does not fix the error, try running PartitionMagic with the /IFC switch, which causes file system errors to be ignored.
To run PartitionMagic with the /IFC switch
Boot from the first PartitionMagic rescue disk.
When you are prompted to insert the second rescue disk, press Ctrl+C to drop to the command (A:>) prompt.
Insert the second PartitionMagic rescue disk and type the following:
pqmagic /ifc
Press Enter.
please go ahead and try the above steps may be it will fix it
Feb 26, 2009 | Symantec Norton Partition Magic-8.0...
Adobe Audition 1.5 Logo
198 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
