I am getting a line through photo I am using special TTC 3.1 paper for hot pressing on tshirts by Magic Touch. This shows on ordinary paper also
  • 5,603 Answers
SOME printers are not capable of handling certain specialty papers. Those that bend the paper as it goes through are sometimes not capable of handling the thicker papers, and especially if it has a backing with a split line to help seperating the backing. This weak spot due to the cut in the backing allows the paper to bend up into the print head.
Printers to use for this type and the thicker material OFTEN have a door at the back to open to have a straight paper path.
Posted on May 11, 2010
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
Feb 25, 2015 | Canon ImageRunner 4570 | IR4570 |
Hello , I think during the firstinstallation I missed something because I do not see colors properly. are very pale. I do not know how to give a general reset.
Perhaps you need to adjust the printer settings in your computer?
Pay special attention to the print quality settings (if Draft mode is default, then you'll get weak colors), and to the paper (media) type - it won't let you print photo quality printouts on plain paper, as normal paper cannot accept too much ink (it would get soaked and colors would blend ugly).
If you put in high quality, expensive photo paper, and in the settings the paper would be set to "plain paper" - you'll get washed out colors on the printout, because the print driver in your system thinks that the paper is ordinary and limits the amount of ink used.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 28, 2011 | HP PS C4780 All in One InkJet Printer
Want all region code for Sony theatre player DAV-X1G
it's possible to unlock with a remote control.I Used a "One-For-All" remote.
This process is working on more that this Sony DVD players.
First prepare the remote control to use right device code.
1: Select the DVD button on the remote
2: Hold "Magic/Set" button util the LED blinks twice (Rabbit appears)
3: Press numbers 0533
Now program the remote control to send special codes on button 1 to 5.
1: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
2: Press numbers 994
3: Press "Magic/Set" button once
4: Press number 1891
5: Wait some time
6: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
7: Press numbers 994
8: Press "Magic/Set" button once
9: Press number 2552
10: Wait some time
11: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
12: Press numbers 994
13: Press "Magic/Set" button once
14: Press number 0953
15: Wait some time
16: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
17: Press numbers 994
18: Press "Magic/Set" button once
19: Press number 2214
20: Wait some time
21: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
22: Press numbers 994
23: Press "Magic/Set" button once
24: Press number 0795
25: Wait some time
Now the remote is ready for use on the DAV-X1
1: Start the DVD without any DVD in it.
2: At the same time press and hold "Eject" and "Stop" in and then press "volume +" to get into the service menu
3: Now use your programmed remote
4: Press button 12345 with a small pause between each num.
5: Press button 12345 with a small pause between each num.
6: Wait some time
6: Press button 12345 with a small pause between each num.
7: Now use your orginal remote and turn the DVD off
Tested to play Region 2 and Region 1 DVDs without any problems after this. (The remote i used was a Cameleon 6)
May 13, 2011 | Audio Players & Recorders
Hi. my photo printing results is not so good on normal paper. plz tell me vat is the problem. i want to print photo in best resolution on ordinary paper.i.e (Double A paper)
Printing photos on ordinary paper do not come out well because the ink soaks into the paper like a blotter. I suggest you use semi-gloss or high gloss photo paper for best photo quality prints..
Feb 25, 2011 | Epson TM-T60 Printer
I don't know how to fax
The control panel LCD also provides menus to operate the copy and fax modes independently of a PC. One nice touch: the LCD displays small and large type on the same screen, allowing more information about a print job to show at one time. b.gif 21262659-2-200-dt2.gif
The flash card reader under the control panel means you don't need a PC to print photos.
The MP730, while easy to operate, lacks some of the advanced features you might find on separate printers or faxes. For example, the MP730 can't collate copy jobs. To make more than one collated copy of a multipage document, you have to place the document in the ADF several times. Nor can the MP730 sync fax numbers entered by hand or accessed from within the Windows Address Book (Canon doesn't provide its own fax/address-book software), so you may end up duplicating efforts. Nor does Canon's software create group dials from your address book on your PC or provide a cover sheet. Finally, the MP730 can't forward faxes to another number or hold a fax to send when nighttime low rates kick in, which other multifunctions do.
Still, the MP730 provides plenty of features we do like. Using the menus with the Photo Print mode, you can print a photo contact sheet, pick individual images to print, and set up the printer to copy or print onto high-quality glossy paper. In the Copy mode, menus let you print two reduced originals side by side or print the same image on the same page several times (useful for business cards, name tags, and so on). The fax engine distinguishes voice from fax, sending voice calls to your phone or an answering machine and sending fax calls to the printer or to buffer memory so that you don't have to get a second phone line installed for your fax.
Installing the MP730 software is slow but idiot-proof: You just pop in the CD and follow instructions, which require restarting your PC several times. Canon bundles the MP730 with ScanSoft's OmniPage SE, a lite version of the best optical-character recognition software on the market, and NewSoft's Presto PageManager 6.0, one of the best document-management databases available.
The MultiPass MP730 won't replace top-of-the-line printers and scanners, but its print and scan speeds keep up with other multifunctions' as well as that of most as midrange ink-jet printers and scanners on the market today. In our tests, it printed ordinary text at 6.4 pages per minute and printed CNET's high-resolution test photo in 3.7 minutes. For comparison, the Lexmark X5150 (only $149 but without fax capability or automatic document feeder) prints text at a more common 5.2 pages per minute, and printed our test photo in about 2 minutes. Canon's MP730 scans a page of black in 9.4 seconds and a page of color in 20 seconds; that's seconds faster than the HP PSC 1210. And the Canon makes copies in 18.7 seconds; that's almost twice as fast the HP PSC 1210.
Unfortunately, the MP730 delivers a mixed bag on image quality. When printing, better paper has a big effect. When we printed text on ordinary paper, for instance, it looked grayish instead of black, and a gray shadow haunted the edges of letterforms, while on coated (not glossy) inkjet paper, text popped out in a solid black and looked much cleaner. Our color photo on ordinary paper looked very dotty, had rough transitions between shades, made a blob of detailed areas, printed lines with jagged edges, and mixed inappropriate colors; coated inkjet paper improved detail and let colors appear in the right hues, though much too saturated. And on top-quality glossy paper, textures, shading, and transitions suddenly looked right, and we saw sharp, clear detail.
Grayscale scans on the MP730 when compared with other scans seemed overexposed, losing paler shades of gray along with some detail, while color scans showed accurate colors and fairly good detail despite somewhat grainy textures.
Jan 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My printer jammed when I tried to print a Tshirt transfer.
Most Tshirt transfer paper is fairly thick you could try a different brand and double check that you are printing on the transfer paper not the thin separtion sheets used to stop the paper sticking together.
Aug 30, 2009 | HP Photosmart C4180 All-In-One InkJet...
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Photo paper draw on C7280
I had the same problem and ended up in a very long chat session with HP online. It was very helpful -- they basically had me reset the printer to the factory settings. Press and hold print photos and red eye removal for 3 seconds. The printer should show Mfg Commands and under that it shows Enter Special Key Combo. In a sequence press red eye removal then print photo then red eye removal. It should then show uiaux and Support VixxFN0724AR. Press the right arrow key twice. It should then show Resets Menu. Press ok. It will then say Country/Language Reset. Press the right arrow key till you get the option of semi-full reset. Press ok. The printer should turn off. Wait about 10 - 15 seconds and then turn the printer on.
I basically told you what the chat session person said. If that doesn't work, I highly recommend that you get online support (it should be free) via their chat support.
Jul 02, 2009 | HP Photosmart C7280 Laser Printer
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
Photo printing
If the printed output smears with a light touch, you may be printing on the wrong side of the paper. There is some photo quality paper that can be printed on both sides (it will say on the box if so), but most photo paper can only be printed on one side. Check the directions that came with the paper.
Apr 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
27 people viewed this question
k24674
jasbo
jasbo
