Question about IBM ThinkPad 600X Notebook
Replaced cmos battery
Cant access bios, and computer wont boot os.  It just hangs with the following on the screen:  '196032 KB OK', along with 'ThinkPad' and 'IBM'  logos.
Aside: Main Batter is dead - so I'm using power cord only...
  • petesza Mar 28, 2008
    Pressing F1 with powering on does not allow me to get to the BIOS.  If my bios is gone,  what do I do?
  • FPMe2 Mar 30, 2008
    Worked fine last week now get error codes 00173, 00192, & 00163 respectively mouse point OK, clock appears. time was wrong. Reset time, and is holding for 6 hours now. Clich OK, get two beeps, screen looks like it booting, get two beeps, and error code 00193. If i push the test selection it will not pass the memory test but hangs up there.
    PLEASE HELP THIS PREACHER IF YOU CAN!
    Thank You and God Bless You!
    Pastor Franklin
  • IBM Master
  • 5,569 Answers
Try this:
Press and hold F1; then power on the computer. Hold
F1 until the “Easy-Setup” menu appears.
If you have set a password, the “Easy-Setup” menu appears
after you enter the password.
Plagiarized from:
http://www.wimsbios.com/phpBB2/topic9023.html
Posted on Mar 28, 2008
  • Steve Allison
    Steve Allison Mar 29, 2008
    Not a certainty, but the BIOS is likely board-mounted (as opposed to socketed).
    If this has failed, it is likely that the main board will have to be replaced.
    What indication did you have that the battery needed replacement?
    That model seems to go back to ~2002 so it was probably due, but which error messages did you receive prior to replacing it?
    On the same board as before, there is a detailed discussion about the BIOS and flashing it for an update, this might be of some further help:
    http://www.wimsbios.com/phpBB2/topic7229...
    Although we are pretty spoiled concerning memory reliability, it is possible that the flash memory has failed.
    It might still be possible to refresh it through updating.
SOURCE:
Why do I get 3 short beeps followed by 3 short beeps ?
Each BIOS manufacturer has its own beep code setup. Find the maker of the BIOS, and here are two places you may find your answer at:
http://www.bioscentral.com/beepcodes/phoenixbeep.htm
http://www.computerhope.com/beep.htm
When the CMOS battery runs low then the BIOS automatically sets back to factory default, but will not prevent the computer from booting.
If you can't find the BIOS maker information, you might try the Acer website, but Acer is notorious for lack of customer help.
http://us.acer.com/ac/en/US/content/drivers
If all the above fails, I hang out at www.suggest-a-fix.com, a free computer help website. Post in the Hardware section and I will be along. This website is really not conducive to easy communication.
May 21, 2014 | Acer Aspire Computers & Internet
Wont boot
Remove ALL media, DVD,CD, USB, etc. Unplug, remove battery, plug in, reboot. If that fails, reseat the Memory Mods. Replace the CMOS battery, remove HDD and test.
Mar 18, 2013 | HP G60-438NR (NW150UA) PC Notebook
My laptop HP ProBook 4510s prompt computer open password befor going to BIOS or OS. And i don't know what is the password? So how can i reset the password to boot the computer.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps you
Jul 25, 2011 | HEWLETT-PACKARD 574508-001 - Original HP...
Bios password wont let windows boot up
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 13, 2011 | Toshiba Computers & Internet
HP Compaq NC6000\r\nWhen I press the power button it seems to start but the only thing I see is numbers going by rapidly in the form of kbytes (524288 KB ok) then it reads 162-system Options not set. Then...
Hi promano67
When you "start" the computer, and the {"Screen"} displays a "Error Message."[CMOS] "error checksum!"
Settings: "Default" loaded.A "checksum error" shows that:
The ("Boot-up Settings "have been changed?"), ie. "Booting OS."
*Boot File 'missing'.
"This can 'occur' if the computer was "shut-down unexpectedly."
Force Shut-down : Power lost; due to 'low battery...'
A ("Power Surge") can cause this 'problem' also.
"What 'happens is that the [CMOS] settings are lost!".
"To fix the problem!"
Do the following:
  • "Restart / Boot the computer.
  • Next, verify if the 'error message' displays?
  • If you are still getting the message?
  • "You will have to "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}._953.jpg *Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
  • Replace the "CMOS battery."
  • Next, "Only plug the Power Adapter into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" _951.jpg
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 13, 2011 | HP Compaq nc6000 Notebook
Bios boot password on a Toshiba c655-s5049
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps dont forget to vote!
Feb 25, 2011 | Toshiba Computers & Internet
Cant do anything my computer wont go to the os
What you need to do my friend is remove the CMOS battery, then remove the power cord from the computer. Press the power button on the front of the pc, you might at this point see a temporary flash of the power LED (at this point the cmos /bios is now cleared and reloaded with the defaults.
Next, put the battery back in and then the power and boot to the bios. Just reload all settings as needed and you should be back in business!!!
Sep 19, 2009 | Dell Dimension 2400 PC Desktop
Error showing on boot
The 161 error means the BIOS battery is dead (flat).
The 163 error means the Date and Time is not updating.
The BIOS battery needs replacing and the BIOS settings need to be configured (ie the date & time)
Mar 31, 2009 | IBM ThinkPad 600X Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Hp 530 notebook cant boot from a cd drive
There is one possible reason for this issue
  1. CMOS battery
Troubleshooting Steps
Open the computer case and find the battery on the computer motherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery. Removed the battery and put it back. This will reset the BIOS setting to default. Change the setting and select first boot device as CD ROM. If that doesn’t work then replace the CMOS battery. After replacing the CMOS battery please change the BIOS setting and select first boot device as CD-ROM.
Dec 30, 2008 | Computers & Internet
IBM ThinkPad 600X Notebook Logo
185 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
