Question about Sony Playstation 3 (PS3) Console
When I press the start up button (red) it turns green, gives 3 beeps and turns flashing red again.
  • zoopmitty May 12, 2010
    what you got is what is know as yellow lite of death --YLOD this
    is the site i got the info from...http://boardsus.playstation.com/t5/PlayS...
    and you are not the only one to experience this. more and more ps3
    owners are getting hit with this problem. your best bet will be to send
    it off to sony if its under warrenty for they'll fix it for free. but
    be cautious of this for they may even replace your system and you may
    not get your original system back. if its not under warrenty you'll get
    hit with an $150 charge. The YLOD is a major
    hardware failure for the PlayStation 3.
    The specific cause is somewhat known, but Sony has not commented about
    this failure whatsoever. Some theories for the cause include:
    overheating (accelerated by dust build-up), blu-ray drive failure, bad power supply, and/or
    a hard drive critical error. **UPDATE** According to an eBay store that
    repairs YLOD PS3's, the hardware failure is caused by either/or of two
    things: 1. Hardware malfunction on the motherboard due to
    heating/cooling (solder physically cracking/breaking) which can be fixed
    by "reflowing", which is a fancy way of using a machine that has a
    super controlled (+ or - .5 degrees) hot air nozzle to re-melt the
    solder on the base of the defective chip to re-attach it. 2. The
    power supply has the failure in one of its capacitors or diodes.
    This can also be fixed by "reflowing" but it is harder to diagnose due
    to the need to chase down which one it is. **According to this eBay store, this
    scenario is a much more difficult way to repair PS3's with the YLOD.
    They state they can only repair 8 out of 10 PS3's with the YLOD** You
    know you have received the YLOD when the following occurs (Can also be
    seen here): * You power on the console. * The console
    starts up normally for about 2-3 seconds, * The console beeps 3
    times while flashing a faint yellow light, * The console
    continues to flash a red light. you can check youtube for ps3 reflow and see some of the vids people have made fixing their YLOD problem. just know if you do go this way you void warranty for opening up your ps3 and this may or may not fix the problem
    President:
  • 1,469 Answers
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Posted on May 12, 2010
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Console wont come on red light goes green then yellow flashes then flashes red
its an error. hold down the power button till it beeps once. the hold it again till it beeps twice. The moment it beeps twice take your finger off and instantly hold it down again. your ps3 with give you 5 onscreen options, hit #3 and only number 3. that should fix the problem. You can also youtube "how to fix disk error on ps3" and people will should you how to do these stated steps.
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot start the correct hard disk was not found
try safemode
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
