Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
Testing appliance? I purchased a Frigidaire Affinity Front Load Washer, they just delivered it. There is water inside, and residue. I asked why its wet inside and the delivery person said that all units are tested. Is this true???? I have bought several washers in my lifetime and never has there ever been any water in the unit. Also the product registration card is wet and molded!!! This doesn't seem right to me. I also found a defective sticker on the side of the "new" machine. Any comments on this?? Please reply. Thank You
Call place you bought it asap, tell them you will call BBB. Then call manufacturer. Then call news media..
Posted on Apr 10, 2008
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Why wont my washer to perform the system clean cycle?
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
Aug 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why does the frfgidaire affinity washer has foul oder ?
Good Morning Friend,
I understand you have an odor in your Frigidaire Affinity washer, model# ATF7000E. Please try cleaning the inside of your washer by trying the following:
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum. Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly with water.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a nonabrasive household cleanser. This prevents dye transfer to future loads.
To prevent the odor from coming back please try the following:
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer, and odors may develop in items left in the washer.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• If there are no small children present, leave the door ajar to prevent odor build up and to improve venting of the unit.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer locks the door then it doesn't start. What's wrong?
Good Afternoon Friend,
I understand the door locks on your Frigidaire Affinity washer, model# ATF7000E, and the load does not start. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
How to clean the inside seal of a frididaire front load washer
I understand you want to know how to clean the inside seal of your Frigidaire washer, model# ATF7000E. Below are instructions for cleaning the inside of your washer, including the seal:
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Affinity ATF7000E Front Load...
FRIGIDAIRE AFFINTY FRONT LOAD DOOR WILL NO CLOSE LAFW7000LWO
I understand the door will not close on your Frigidaire Affinity washer, model# ATF7000LW0. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
E21 frigidaire affinity won't drain
I understand you are receiving an E21 code on your Frigidaire Affinity washer, model# ATF7000E, and it is not draining. The E21 code can possibly mean that the water is not draining out fast enough. Please check the drain hose for any kinks or clogs. Also, make sure that your home's drain pipes are not clogged as well. This could also be a false code. Try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why wont the door lock on my affinity washer?
I understand the door will not lock on your Frigidaire Affinity washer, model# ATF7000E. I suggest resetting your appliance, by either unplugging it or shutting it off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
Problem with water in tub of front load washer
Two possibilities here - bad valve, not closing completely when off or you have a bad control that is sending residual voltage to the valve when it is off. Contact a service technician.
Aug 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
