Question about Maytag MSD2758GEW
Fresh side not getting cold, Freezer OK
Maytag MSD2758GEW Fresh side not getting cold. Feezer seem OK... I don't see any ice build up anywhere.
I have checked to see if the condenser fan is running, it is. I can change the temp to off and I hear the fridge shut down... I move temp back up the scale and it turns back on.
And the crisper drawers seem cold... at least colder than the upper part of the fridge.
  • 821 Answers
Hello,It is possible that your adaptive defrost assembly found inside the fresh food section and behind the control panel is defective. If not we need to check the defrost heater and the defrost thermostat
61005988 Adaptive Defrost Assembly
wish you good luck,
take care.
Posted on May 11, 2010
  • calgeek May 11, 2010
    Is there a way to bypass this to check if it's the problem?
  • Hammid Disu May 12, 2010
    hello,there is no other by pass,this is the problem below.
    hello,It is possible that your adaptive defrost assembly found inside the
    wish you good luck,
    take care.
Whirlpool fridge WF258 freezer works perfectly; but fridge is in room temp, not working at all,light is ok
Damper door between freezer and fresh food not opening or build up of ice not letting cold air in fresh food side may have a defrost problem if you have a lot of ice on back wall of freezer
Nov 20, 2016 | Whirlpool Refrigerators
Maytag 21 cu ft top freezer, not getting cold enough
whats not getting cold ? freezer or fresh food? if FF check for defrost problem by feeling back of freezer panel for ice build-up,
Oct 14, 2013 | Maytag Refrigerators
Maytag msd2655 freeze work good,fresh food side not cold
HI TRY DEFROSTING ALL FIRST.MIGHT HAVE ICE BUILD UP AT THE BOTTOM.IF IT WORKS GREAT. IF NOT THEN FURTHER INVESTIGATION REQUIRED.SERVICE COND/UNIT.GOOD LUCK ALI
Jul 12, 2012 | Maytag MSD2656G Side by Side Refrigerator
Fridge side warm freezer still seems okay
frig side is warm due too no cold or air getting to fresh food side . i would ck for ice on the cold coil in freezer . this is most common .. mm
Oct 22, 2010 | Maytag MZD2766GES Side by Side...
Refrigerator not cold freezer working properly turned food section to max, cleaned coils
loook for ice build up in back of freezer . and if found you have a failed defrost system .. the coil is blocked with ice and this prevents the cold air form getting to the fresh food side . look at the heater in the back of freezer ... mm . if heater is ok then replace the adative defrost control . / a very common part failure .. mm
Sep 30, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator is not very cold. Freezer is not
Our side by side did the same, started because the cooling coils on the bottom (although cleaned regularly), still overworked due to build up of dust and especially pet hair. The heating coil in the freezer compartment which prevents ice buildup in modern (frost-free) units kicks on full time and the compressor can't compensate, thus your perishables start to thaw. Luckily we were still under warranty. hope this helps you at least start diagnosing the problem.
Nov 24, 2009 | Maytag MSD2758GEW
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Maytag MSD2758GEW Logo
57 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
