Question about Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
How do i get to the impeller model fp 5172-08
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Panasonic error code E01-22 Model FP-D250 Need a Laser unitl where can I find one
A new laser would be over $100, it would be much cheaper to buy a new copier.
Mar 03, 2011 | Panasonic FP-D250F Copier
How to remove linker error in Tc C++ 3.0 in graphics.h header file and iomanip.h and msoftcon.h and windows.h
#include<stdio.h>
#include<conio.h>
#include<string.h>
#include<stdlib.h>
#include<ctype.h>
struct student
{char name[20];
int rollno;
int mark;
void main()
int ch,f,roll,i,j,l;
char name[20];
struct student k,t,d[50];
FILE *fp,*temp;
clrscr();
fp=fopen("stud.c","wb");
fclose(fp);
while(1)
{printf("\n=========================\n");
printf("\n\n1.Insert\n2.Display\n3.Search\n4.Delete\n5.Sort\n6.Update\n7.Exit");
scanf("%d",&ch);
printf("\n==========================\n");
switch(ch)
case 1:
printf("\n Enter name");
scanf("%s",k.name);
printf("\n Roll no:");
scanf("%d",&k.rollno);
printf("\n Mark");
sanf("%d",&k.mark);
fp=fopen("stud.c","a+b");
fwrite(&k,sizef(k),l,fp);
fclose(fp);
break;}
case 2:
fp=fopen("stud.c","rb");
while(fread(&k,sizeof(k),l,fp)!=0)
printf("\n name:%s \t Rollno: %d \t Mark:%d",k.name,k.rollno,k.mark);
fclose(fp);
break;
case 3:
{f=0;
printf("\nEnter the rollnumber to be searched :");
scanf("%d",&roll);
{ if(k.rollno==roll)
f=1;
printf("\n Name:%s \t Rollno:%d\t Mark:%d,k.Name,k.rollno,k.mark");
if(f==0)
printf("searched item does not exit");
fclose(fp);
break;
case 4:
f=0;
printf("enter the roll no for deleting the record:");
scanf("%d",&roll);
temp=fopen("temp.c","wb");
if(k.rollno==roll)
f=1;
else
fwrite(&k,sizeof(k),l,temp);
fcloseall();
if(f==1)
temp=fopen("temp.c","rb");
fp=fopen("stud","wb");
while(fread(&k,sizeof(k),l,temp)!=0)
fwrite(&k,sizeof(k),l,fp);
printf("record deleted");
else
printf("roll no not found");
fclose(fp);
fclose(temp);
break;
case 5:
i=0;
while(fread(&d[i],sizeof(k),i,fp)!=0)
i++;
fclose(fp);
for(j=0;j<i-1;j++)
for(l=j;l<i;l++)
if(d[j].rollno>d[l].rollno)
t=d[j];
d[j]=d[l];
d[l]=t;
for(l=0;l<i;l++)
fwrite(&d[l],sizeof(k),l,fp);
fclose(fp);
printf("\nsuccessfully sorted");
break;
case 6:
f=0;
printf("enter roll number to update:");
scanf("%d",&roll);
if(roll==k.rollno)
printf("enter the new record name,mark\n");
scanf("%s%d",k.name,&k.mark);
f=1;
else
fcloseall();
if(f==0)
printf("roll no is not present");
fcloseall();
break;
case 7:
exit(1);
break;
Nov 25, 2010 | Borland Turbo C++ 3.0 Full Version...
Whirlpool 6th Sense displaying FP and clean pump is lit ! How do you clean pump ?
On the lower front panel is a small door which may be behind the kick panel. Behind this door is the drain filter.. Do not undo this filter till you have emptied the machine, as any water in the machine will flow from the pump, when opened.. Leaning the machine back against the wall will help contain what water is left in the machine..
Undo filter, check and clean.
Check that a coin or hairclip has not fouled pump impellers.
If the impeller has come away from the pump shaft, the pump motor needs to be replaced.. A tech should be called for this job!
Good luck....Nomess
Aug 04, 2010 | Washing Machines
I have AWO3761 and increasingly frequently the clean pump light is lighting up and FP is diplayed during the wash cycle. The machine is still full of water so I empty it and take the filter out which is...
check your drain hose sometimes coins get through the filter and get into the hose also the pump may be bad the impeller sometimes break and it will not pump out the water
Jul 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
I need plain paper fax panasonic kx-fp 200 immediately
The refills that fix the kx-fp135 will also fit your model kx fp 200. Office Depot has this and it can be ordered onlin. : http://www.officedepot.com/a/products/288514/Panasonic-KX-FA136-Black-Imaging-Film/
Apr 16, 2009 | Panasonic KX-FB421 Plain Paper Film Fax
Need manual for iRiver FP-795
This happened to me too. I went to the iriver website and downloaded the appropriate model software (in your case FP-795) for transfering mp3's. Its been working great since.
Jan 03, 2009 | iRiver iFP-795 MP3 Player
Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v Logo
108 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
