Question about Peg Perego John Deere Gator HPX Ride on Toy
Bought this used.. Plugged in the battery but it doesn't work (and the battery is good). Is there an on switch or a key or something to turn it on?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Jun 14, 2012
Relay switch or fuses
If the battery is good, then there should be power at the starter solenoid. The solenoid is connected to the starter.The solenoid is energized by the ignition key. When the key is turned, the starter solenoid allows power to feed the starter. Try tapping the starter solenoid while turning the key. Have a friend help and use something non metallic to tap the solenoid. Good luck!
Feb 18, 2016 | Cars & Trucks
Doesn't start, not even a cranking noise
If it does not crank, it could be the key switch, the neutral safety switch, or the starter.
While you are under the car you need to check to see if you have power on the purple wire at the starter solenoid when the key switch is in the start position. That is power coming from the key switch thru the neutral safety switch that energizes the starter solenoid.
Jun 18, 2013 | 2001 Pontiac Grand Am SE
1996 Toyota tercel doesn't start doesn't crank
Well you may have more than one problem.
As far as cranking, a mechanic would check for voltage at the starter and trace back to the key switch. The key switch could cause both problems. There is also a neutral safety switch that could cause it not to crank.
You could also have a bad ground connection between the engine and body.
Dec 11, 2012 | 1996 Toyota Tercel
Battery is brand new, connection is good at the battery. All fuses are good. Turn key on and nothing happens. We ran a wire from the postitive side screw on the fuse box to the pos lead off the battery and...
You've checked the connection from the fuse to the batterie but have you tried to bypass the keyswitch, it could be the switch doesn't connect inside or the key doesn't turn the switch inside.
Jun 11, 2011 | 1987 Suzuki GV 1400 Cavalcade GT
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Why cant anyone hear me on my turtle beach headset for ps3?
could be your settings try to monitor your own microphone when you talk. could also be break in the microphone cable. check the its plugged into red socket not pink it should have a microphone symbol
Mar 02, 2011 | Voyetra Turtle Beach Ear Force X3 Wireless...
Bought a maglite 2-cell D today, put batteries in..no power at all.. help :)
make sure battery is good. Did you install batteries correctly? flat side (-) in first. Try adjusting the head where it screws on.turn in both directions. Last if this doesn`t work -return it for an exchange where you bought it..
hope your not in the dark..
Feb 25, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
Sony playstation portable
It might be a problem with your battery pack, you can even switch on your psp without battery pack, with the charger plugged in acutally. So a replacement battery will be a good choice for you.
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
Keyboard
That's strange...a suggestion (long shot) you can check out....some keyboards come with software that allows you to remap keys...possible I suppose that the n key was remapped to something else... Good luck
Aug 27, 2007 | D-Link DKVM-2K 2-port KVM Switch
Battery charge
the battery is dead. that happened to me and i had 3 choices: 1)buy a new dvd player 2)buy a new recharable battery or 3)keep the portable plugged to the wall while i watch movies. i chose number 3 because i usually just use it at places plugs are available. but yeah, the battery is dead.
Jan 27, 2007 | Insignia I-PD720 Portable DVD Player
Peg Perego John Deere Gator HPX Ride on Toy Logo
55 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
