Question about Frigidaire 22.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
Frigidaire Model FRS26R2A refrigerator is not staying cool
I have a Frigidaire model FRS26R2A refrigerator. A week or so ago I noticed that the refrigerator was not as cold as what it once was. I turned it down lower, but the temperature did not change. The freezer is fine. Any thoughts. Thermostat maybe?
22yooper
  • 828 Answers
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Posted on Sep 15, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
aborcass
  • 2651 Answers
SOURCE: Freezer Not Freezing
sounds like youll need to order and install one of these, its too cold in your garage to operate normally, this is a simple solution that should correct your issue
http://www.frigidaire.com/tip/US%202008%20Service%20Flashes%20and%20News/Refrigeration/2008/Service%20Flash%20RF083FRIG%20Garage%20Kit%20for%20Top%20Mounts.pdf
Posted on Jan 21, 2009
  • 531 Answers
SOURCE: Refrigerator and freezer too warm
you may have defrost problem
Posted on Apr 07, 2009
heatman101
  • 43501 Answers
SOURCE: FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Won't cool
Good Afternoon Friend,
I understand your Frigidaire refrigerator, model# FFTR1713LW6, is not cooling. We are into the summer months now, so it could possibly be that it is getting hot and humid, and I suggest lowering the temperature inside your refrigerator. Give it 24 hours for the temperature to stabilize. If you are still noticing that your appliance is not cooling, I suggest contacting your local authorized technician, for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Refrigerators
Model FRT045GB
Good Morning Jr. Riojas,
I see that you are having trouble with your Frigidaire compact refrigerator, model# FRT045GB, and it not cooling. I also see that you have reset your refrigerator, by unplugging it, and it works fine for two weeks, then you have to repeat resetting it. I suggest contacting either the manufacturer or your local authorized technician for further assistance. They should be able to better assist as to why your refrigerator cools for a few weeks and then you have to unplug it for it to cool a couple more. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire 4.4 Cu. Ft. Compact...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
I bought a upright frigidaire model ffu2124dw7,serial# wb63943076.Bought it a year ago and I have found that within a short period of time there a substantial amount of ice build up on the cooling...
ice formation depends in part on how often and for how long door is open but also worthwhile checking the door seal with a slip of paper trapped between seal and cabinet
Sep 17, 2008 | Frigidaire Refrigerators
Frigidaire humming freezer not cold enough
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
2003 Frigidaire FRS26BH6CBO Side By Side Problem
DEFROST PROBABLY SET TO AUTOMATIC..NEEDS TO BE REPLACED THEN ALL WILL BE WELL
Jun 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator does not cool. Electrolux FRIGIDAIRE we moved into a new construction condo and all appliances were new we liveed in it for 6 weeks frige was fine but loud it is a model GLRT 13TEW4 serial...
If the unit is less than 1 year old call Frigidaire factory service. In the mean time check in the back of the freezer or in air channels for frost build-up. It may indicate a defrost problem or air leak. still best to have factory tech check if in warranty.
J
Jun 13, 2008 | Refrigerators
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Open Questions:
See all Frigidaire 22.5 Cu. Ft. Counter-Depth Side-by-Side Questions
Frigidaire 22.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
