Question about Microsoft Xbox 360 Console
0102 to fix a 0102 error
    President:
  • 1,382 Answers
0102 Error in the "Digital Backbone" (CPU/GPU/RAM) is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this. One deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call Microsoft to have it replaced.
Thank you!
Posted on May 12, 2010
    Problem Solver:
  • 11 Answers
Try heat gun fix on low setting for 3 minutes. Do not concentrate the heat in a particular spot; heat gun both sides. Reapply paste etc. Keep bolts as loose as possible to avoid the motherboard bending and breaking the solder points.
While you're at it, make sure the fan and heat sinks are clean. Dust won't help get the heat out.
Posted on Nov 24, 2010
2 Suggested Answers
  • 154 Answers
SOURCE: Xbox 360 has 3ROD w/error code 0020. It used to be 0102
Open your Xbox again, remove the motherboard and take off the heat sinks.
Clean the heat sink compound off of the the CPU, GPU, and both heat sinks using 91% alcohol. The CPU & GPU should be as shiney as a mirror when your finished.
The next step is to apply Artic Silver 5 Thermal compound to both processors using just enough to cover the processors, then put your system back together again and give it a try.
If it still doesn't work you may want to try to find someone who knows how to do a reflow. If you go this route, becareful who you choose. Ask for referrals and most importantly, ask for a picture of the equipment they will use to "attempt" to fix your Xbox.
If you get a picture of a standard Heat Gun... find someone else.
Be aware that even after a reflow, your Xbox is still subject to failure again. Microsoft can't even fix them permanently.
You're already familiar with opening your Xbox and taking it apart so you may want to consider learning how to do a reflow yourself.
There's also the option of buying a new Xbox but there's a good chance you'll still be facing another failure in the future. the difference will be that the new Xbox will be covered under warranty for a period of time depending on the problem.
I've heard that new consoles with a Jasper cpu tend to be more reliable but I've not seen any scientific data to back up this claim.
Good luck, I'm in the same boat with 2 broken and have decided to buy a reflow station to repair my own instead of paying Microsoft.
If you think this information is helpful to you, please take a few minutes to rate this reply.
Posted on Aug 29, 2009
Testimonial: "Thanks, I have everything I need too fix it lol. I just want to sell this one so I can get a better one. Mine is a older release one. Thanks lol."
0102 error after xclamp fix
Thank you!
Jun 20, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: error code 0102 for x box 360...
0102 unknown error
  • though it's most likely GPU related literally means the console does not know what is wrong. possibly a short or cold solder joint somewhere. So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection.
    There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced. I have also heard of limited success by simply switching the AV cable from "HDTV" mode to "TV" mode.
May 17, 2010 | Microsoft Xbox 360 Console
I have the 0102 code on my Xbox 360 can this be fixed and how?
The XBox error code 0102, is an error in the digital backbone or the CPU or GPU or RAM. This error is generally caused by a cold solder connection between the main board and the GPU. I would recommend calling microsoft about fixing it.
Dec 22, 2009 | Microsoft Xbox 360 Console
Red ring of light 0102
Hi!
For detailed information on how to replace the X-clamp, follow this link:
http://forums.xbox-scene.com/index.php?showtopic=595746
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Jan 10, 2009 | Microsoft Xbox 360 Console
ERROR CODE E00002-0102
You have a fuser problem. You didn't specify a machine but if it is the irc/clc3200/3220/2620 you will need to replace the fuser unit. If you have a different model where the fuser thermistors/thermal fuses etc can be replaced then replace according to the manual.
Canon Copier Sevice Manuals
Oct 25, 2008 | Canon imageRUNNER C3200 Color Printer
Error code 0102
If you're comfortable enough opening your 360, you can try this tutorial, which has worked for many people.
Jan 07, 2008 | Microsoft Xbox 360 Console
Error code 0102
Error code 0102 is still unknown The xclamp mod is a possible fix for this error there is also a possability that the error is caused by a bad soldering join on your cpu, gpu or your ram. I would check all those parts with a magnifiying glass to make sure that there are no cracks in the solder. Another way to possibly fix this is to turn off your HD format on the AV cables this might work.
Dec 11, 2007 | Microsoft Xbox 360 Console
Xbox 360 error 0102
do the erasor trick. its like magic
Nov 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
110 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
