Question about GE Microwave Ovens
Can i replace just the timer on a JKP97G GE microwave. The thing's 30 years old but the client is elderly/fixed income and the unit works fine except the timer sticks regularly. If i can't is there a unit that is of the same size as this particular microwave/oven combo?
  • 821 Answers
Hello,it can be replaced and you can kindly place your order from this company link below,
www.appliancepartspros.com/part_details.aspx?part_id... - United States -
wish you good luck,
take care.
Posted on May 11, 2010
  • 1 more comment
  • JOHN THOMPSON May 11, 2010
    They don't have it. Only supplying for model numbers that are followed by an "06" or later. This one is an "03". Not surprising, it is from 1978. Any ideas, or at this point What's a no - frills, stock replacement for these Microwave/Oven combos? Pretty big hole to fill.
    Nope. Only have parts going back to models that are followed by "06" or higher. This one is "03"
  • Hammid Disu May 12, 2010
    hello,you can Kindly visit the site below to see varieties of ge microwaves and other makers microwave that has oven combo's as your GE JPK97 MICROWAVE......
    www.nextag.com/combination...microwave-oven/stores-html -
    WISH YOU GOOD LUCK,
    TAKE CARE.
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Microwave part
GE JVM 1660 Microwave. Everything is working fine except it will not heat.
Apr 13, 2008 | GE JVM1660 Microwave Oven
GE Profile Spacemaker II Microwave won't beep
hi,
The control board may need to be replaced, check your records to see if the unit is still in warranty, if it is call for repair. If it's not and you’re handy, you can find the part online and replace it yourself, just make sure you unplug it before you work on it. Please contact me if you need help.
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
147 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
