Question about Maytag PYE2300AY Electric Dryer
Rattling noise My dryer makes a bad rattling noise when its on but it dryes the clothes just fine!!!
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Posted on May 13, 2010
Testimonial: "I tried doing what you said and It worked a little bit it got rid of some of the noise but not all at least it's not so loud it can be heard all over the house so Thank You very much for the help!"
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
My clothes dryer is making a rattling noise. How can I find out if it is worth fixing or getting another clothes dryer
check these parts:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Oct 29, 2010 | Dryers
My LEV 4634 PQ0 dries the clothes fine but make a very loud rattling noise-anyway to quiet this machine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 13, 2010 | Whirlpool LEV4634 Dryer
Dryer is making a rattling noise when in operation. Dryer is eight years old of so. Never heard this noise before.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Jun 13, 2010 | LG DLE2532W Electric Dryer
My dryer drum is off kilter, eats clothes. leaves black stains on them and is making a rattling noise
The rear supports have gone bad. Part # 37001042 approx. 14.00 ea. You need to do both of them. Hope this helps and good luck.
Jan 28, 2010 | Maytag SDG3606A Gas Dryer
Whirlpool dryer doesnt dry clothes
If the dryer heats , dry a load without the duct on . If it dryes fine , then problem still with vent somewhere .
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
Am not buying...........need help with a problem
If you lift the top of the dryer or the side theres a plastic band that holds the barrel..If you lube that band it will stop squeaking..Just dont add to much lube just enough to stop the noise..Hope this was helpfull
Jun 26, 2009 | Dryers
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Maytag PYE2300AY Electric Dryer Logo
325 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
