Question about Maytag Washing Machines
Remove hose screen at washmachine
Can you remove the screen on the back of the wash machine where the cold water hose connects to the machine? Mine is plugged and I can not seem to get it out to give it a proper cleaning. Any tips or tricks?
  • 311 Answers
Unfortunately the screen that you are seeing is part of the inlet valve. There is not really any way to clean it you would have to replace the valve. The other option would be to take a drill bit and drill out the screen. However this could eventually cause the valve to leak or stick open which could cause flooding so I wouldnt recommend it for anything but a temporary fix. You could also try removing the valve and soaking it in CLR. Hope this helps _MJ_
Posted on May 11, 2010
Testimonial: "Thanks, I will try the CLR for now, you are very helpful and quick to reply"
My washing machine model mw512 will not fill properly on the cold cycle - it just dribbles. I have checked the hose which is fine and the hot works ok also.
this is a sign that the hot/cold mix valve is bad and not opening properly.
the valve is the small plastic part that both hoses go into on the back of the machine,, if you remove the two hoses and the back panel from the machine - the valve is held in place by one little screw. there are four wires that connect to the valve -- make sure you label the hot water wires and the cold water wires. your local appliance repair shop will have this part on hand and they will sell it to you for around 25 dollars.
c...
Jan 29, 2011 | Fisher and Paykel Fisher & Paykel Washer
When i try and start the washer it hums it won't fill it spins just won't fill
Hi and welcome to FixYa, I am Kelly
Turn off the water at the wall connection remove the hoses noting the positons of HOT and COLD. Then clean the inlet screens in the water valve. (lift out by using a knife blade on the outside of the screen) Wash the screens by rubbing your fingers ofer them under slow running water then reinstall them.
Before you start try a hot wash.. and then cold wash to see if either has water coming into the machine. If it works there is a way to back flush the water valve using a warm water wash. You remove one hose and stick it in a bucket. Turn ON the other hose and let water flow into the bucket while gentily tapping on the hose connection with a screw driver HANDLE. Reverse hose connections and repeat hose in bucket and tapping on hose connection. Reconnect both hoses then try HOT and COLD wash fill cycles. Let me know what happened.
Thanks for choosing FixYa,
Kelly
Dec 13, 2010 | Admiral Washing Machines
My washer is not filling up with water fast enough and I'm getting an error. I want to remove and clean the filter where the inlet hose screws into, how do I do this?
You may or may not have screens in the end of your hoses. The screens should be at the end where they connect to the faucets. Turn off your water supply and remove the hose(s) both from the machine and the faucets. Check the ends of the hoses for the rubber washers with screens. You can remove them (if they are present) with a small flat-head screwdriver. After removing them you can wash them out in the sink to remove any debris. Also take a look inside the valve at the back of the machine where the hoses connect to see if there is any debris there as well.
BEFORE you hook everything back up to the machine run the water from each faucet into a bucket at full speed to clear any sediment that may be laying in the pipes.
Re-connect your washer and give it a shot!
Sep 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
Kenmore 80 series washing machine - cannot get
Hi and welcome to FixYa. I am Kelly. This sounds like either the hose or the water inlet valve screen is clogged. Possibly the pinhole inthe diaphram itself of the water valve. Here is what you can do.
1. Get a bucket
2. Turn off BOTH water valves at the wall.
3. Remove the HOT water connection at the water valve. Then check the inlet screen for debris. You can remove the screen from the water valve by using a knife blade on the very outside edge of the screen tugging outward. Hold the screen up to the light check it for debris. If it is dirty wash it under a light flow of water in the sink. DO NOT reinstall just screen just yet.
4. Use a measuring cup or something similar to catch water at the water valve HOT connection. Select a WARM wash cycle and start the wash cycle. Let the water flow into what ever it is you use to catch the water exiting the HOT water connection.
Tap on the cold water hose connection to try and free the debris inside the water valve as the water is flowing. Do this a few times until you have let water back flow through the water valve for about 20 seconds.
Machine timer off.
5. Reinstall the inlet screen in the water valve and reconnect the hose. Place the HOT water hose in the bucket and start the WARM fill cycle again. This will flush the hose.
Machine timer off.
6. Reconnect the hose at the wall connection and turn on the water at the wall.
7. Select HOT wash and test water flow. It should by now be (fingers crossed) flowing.
You can repeat the above for the cold water side if you need to.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Cold water fill is super slow
Do this:
1. Un-plug the washing machine
2. Shut off the cold water supply valve to the machine and then disconnect the cold water hose at the machine. Place a small container under the fitting when you do this to catch the water that will probably leak out.
3. Place the disconnected end of the hose in a bucket or the sink if you have one and SLOWLY turn the cold water back on. make sure the water pressure coming out of the hose is good. If so, the problem isn't there. Turn the valve back off.
4. Set the disconnected hose aside. Take a good look at the connection on the machine (where you disconnected the hose). There should be an inlet screen. It's common for these screens to plug up once in a while, especially if you are on well water. Remove the screen and clean it, being careful to not lose the washer. The screen can be rinsed out in a sink. Look for any other debris that may be in this connection.
5. Re-install the screen, re-install, the hose, turn the water back on slowly, and check for leaks. Plug the machine back in.
6. Try filling the machine again with the washer empty, just in case some muck also comes out so you don't stain your clothes.
7. If it works ok, you're done. If not, then the water fill valve itself may not be working properly and may need to be replaced.
8. A weak electrical connection to the fill valve can also cause this condition, but it's usually the inlet screen.
Good Luck and re-post if you have further questions!
Feb 02, 2010 | Washing Machines
The cold water is running slow into the washing machine
Turn the water off.Remove the hoses look at the machine where the hoses connect. Some units have small screens installed in the machine connection places to filter the water.Mine were cloged with some white stuff. I picked the screens out and cleaned them.
You might even place the hose in the drain pipe before you connect it back to the machine and turn it on all the way to help flush the line out.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer cold water takes forever to fill
your cold side on water valve may need the screen cleaned.if that doesnt help then you will need to replace your water valve.take hose off cold water side of water valve and you will see the screen.it may have alot of blockage.
Jan 04, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Slow cold water
1.) turn off water valve that supplies cold water to washer.
2.) unscrew the cold water hose-type connector immediately next to the set of 2 water connections in back of unit.
3.) look into the hose you just removed or into the water connector on machine. you will find a metal screen (like a window screen) that is cone-shaped...if none found then remove hose connection at other end of same hose...remove it and then clean it thoroughly and then re-assemble all.
Nov 28, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
