Question about Echo Garden
My echo leaf blower shuts down after a few minutes of operation, I have replaced fuel lines and Gas
  • 1,305 Answers
I would also take the air filter element off and clean and reoil it. You may be pulling sufficient fuel, but if there isn't enough air in the mix, your leaf blower will stall out.
I would clean the air filter, and you may want to take the carb unit off and spray it out with aerosol carb cleaner. The carb cleaners are available at local auto parts houses, and it comes with a small spray tube to put on the nozzle so you can pinpoint the spray into the carb jets etc.
Also change your spark plug as they get fouled due to the fuel oil mixture..
best of success!
Posted on May 11, 2010
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
Echo pb 251 leaf blower leaks oil
You need to check your gas line and the primer ball itself and make sure you don't have a split in the lines or in the ball, also check the fuel filter in the gas line to ensure it is not plugged up.
Apr 24, 2014 | Echo Pb-251 Leaf Blowers
Gas leaking from grommet that goes into the gas tank.model pb-2111.
replace grommet. you may want to replace the fuel lines to you can use echo part number # 90098. its a fuel line kit and it come with all fuel lines, grommet, fuel filter, and vent. its plug and play.
Sep 21, 2011 | Echo Garden
Only runs upside down. When right side up it acts like it runs out of gas
Sounds like fuel line problem. Empty fuel tank,remove black fuel line grommet,check for line break or disconnection.If line is broken , purchase fuel line kit with grommet as a set if lines or grommet are deteriorated.
Aug 29, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Sep 21, 2009 | Echo Garden
Gas is leaking from the leaf blower.
Unless the tank has been cracked, it has to be one of the following: Broken lines, split primer bulb, unsealed fuel cap, bowl gasket of carb. I would start with the lines and bulb since they are the ones usually at fault..Good luck...Lee
Sep 04, 2009 | Echo Garden
Open Questions:
Garden Logo
612 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
