Question about Ducane 30400040 Stainless Steel Grill
Burners will not stay lit
I replaced the burners and when I turn them on they will not stay lit. Bran new tank of gas. is there something special that I need to know about burner replacement?
  • 494 Answers
It could be a number of problems. The burners you installed may not have the air adjustment set properly. Each venturi tube has a opening for air at the gas valve orifice. Change the setting and see if it helps. It's also possible, but not likely, that the tank you got wasn't purged properly if it was new. Another possibility is the excess flow valve in your gas hose is checking and only allowing a trickle of gas to come thru. Close the tank valve, wait a minute and then open the tank valve slowly and try lighting it again. Hope that helps!
Posted on May 15, 2010
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
My gas grill when turned on will not stay lit sometimes 'When lityou can here air or something blowing and the flames are real low it doesn't even cook its so low I have it on high when we first got it, it...
Susan - Assuming that you have a Propane grill with a grill tank, that has plenty of gas in the tank. Do the following:
  • Turn the Propane tank valve OFF.
  • Disconnect the hose from the tank.
  • Wait 5 minutes and reconnect the hose to the tank valve.
  • Turn the Tank Valve ON, VERY, VERY SLOWLY (slow motion, slow).
  • Once the valve is fully open, light the burner farthest from tank, first.
  • Turn the burner flame to High. Has the flame height returned to normal? If so, light the remaining burner(s) the same way.
  • Have all the burner flames returned to normal? If so, you solved the problem.
  • Always remember, when turning the tank valve ON, do it VERY, VERY Slowly.
If the above did not solve your problem, you will need to replace the grill's hose/regulator assembly. You can find them at any home center or hardware store that sell grills and accessories. Be sure to take you old one with you for comparison purposes.
Hope this helped you solve your problem. Please be kind enough, not to forget to rate my response to you. Thanks and Happy Grilling!!
Apr 14, 2011 | Uniflame Grilling
Will not stay lit,I have a new gas tank and it light the first burner but will not light others and will not stay lit
Turn off the propane tank and disconnect the hose from the tank. Wait 5 minutes, reconnect the hose and turn the tank valve on very, very slowly, until it's completely open.
Now light each burner one a time and turn it to high. If the burners all light and the flames remain burning on high for more than a few minutes, you're back in business. Just remember to turn the tank valve on very, very slowly after turning it off each time.
If the above didn't solve the problem, are you sure you tank gas a significant amount of gas in it?
If that's the case (empty tank), when you replace it, do exactly what I said above when you connect a full tank to the grill hose.
Hope that solved your problem. Happy Grilling!
Feb 12, 2011 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Grill will not stay lit if using 4 th burner will only work on 3 burners and gas is low
Check that the fourth burner tube is set properly into the unit. Then turn all burners off, turn off the natural gas supply or remove the LP tank. turn all the burners on (don't try to light) wait a couple seconds turn all burners off. reconnect gas source. turn on gas, open burners fully and try to light.
Aug 08, 2010 | Jenn-Air Grilling
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Our grill doesnt seem to be getting enough gas to stay lit. when you turn the burners on your hear the gas coming through for 2 seconds..then nothing, and it wont stay lit
How are you turning the grill on and off? It sounds like a vapor-lock. Try this: first unhook the regulator and crack the valve on the tank open...if you hear and smell gas coming out, good, close the valve and re-connect the regulator then open the gas valve then turn the burner on and light it...then shut it off by closing the tank valve first and let the burners go out then turn off your burner valves...try that and let me know what happens.
Sep 06, 2009 | Grilling
Grill wont stay lit
These new tanks have a safety device installed in them . If you open the valve quickly or tip the jug the damn thang won't work. Take the tank loose, open all the grill valves and close all valves. Reconnect the tank and SLOWLY open the valve a hair. Light the burners. No need to open the valve all the way. if you do the dumb safety will plug the jug.
May 08, 2009 | Brinkmann Charmglow 810-7600-S Grill
Cant get my waterheater lighter to reignite
Sounds like the gas valve has failed. The gas valve can be replaced. It will unscrew out of the tank. Shut the water supply to the tank off and get the new gas ready to screw in. Take out the old and screw in the new, you will onlt lose about a cup or two of water if you are quick enough. Otherwise drain the tank down if you must. If you are going to replace the gas valve I would also replace the thermocoupler.
Dec 18, 2008 | Water Heaters
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Ducane 30400040 Stainless Steel Grill Logo
435 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
