Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
I have Craftsman 36cc 16in Model-358-350461no oil to the bar.
I have Craftsman 36cc 16in Model-358-350461 chainsaw. Cannot get oil to the bar....I have cleaned the channels from the bar side but still no oil...how do I get into the oil tank to check filter and lines.....?? If you have a brakdown please send it. Thanks for your time.... Please send to apantalion@aol.com.
    President:
  • 2,220 Answers
We are prohibited from contacting you directly.
Oil System Plugged:
1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution.
• Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out.
• Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability).
• Start the saw and see if it oils when revved up (oozes down side of saw).
• If yes reassemble your saw. If no, continue with 2.
2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go.
• Carefully check the hoses for cracks especially at bends and connections.
• If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread).
• Please make extensive notes & some digital pictures will help during reassembly.
3. If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL for the location).
The IPL (exploded parts list) for your saw is the only detail for the oil system, it is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358350461&productCategoryId=1503220&brandId=0247&brandDescription=CRAFTSMAN&modelName=CHAINSAW&diagramPageId=00001&componentDescription=CHASSIS%20BAR%20CHAIN&documentId=P0205138&blt=06
It appears to have an outboard clutch, this will be helpful;
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 11, 2010
Repair manual for craftsman 32cc 16in chainsaw
go to www.managemylife.com enter your model number in the search bar under the manual tab. your model number will be a 9 digit number on the id plate, it will start out with either 917 or 247.
Nov 15, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a craftsman gas chain saw model 358.352180. It leaks oil from underneath the saw even when not in use.
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
May 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Not geting the bar oil to the bar. clogged somehow.so chain get very dry and won't cut very well.
How about a model and serial number (post below)? I want to look at the exploded parts lst and need your help. Lou
Apr 04, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
On my 16in craftsman saw the oiler quit working
some times this can be something easy sometimes not just follow a few simple steps:
Have you replaced the bar and chain recently?
#1 Remove bar and chain and blow out all sawdust esp around your bar studs dont get to close with the air as you can sometimes pop seals...
Start your saw see if oil comes out around bar studs if so the oil holes in your cutter bar may be blocked...
#2 If that doesnt work remove your oil filler cap and use a piece of wire with a bend on the end to remove your oil filter remove it from oil line and clean in fuel and blow out with compressed air replace on hose and place back into tank and try start chain saw again...
if that doesnt work then take it in to small engine repair shop as the pump may be blocked or unservicable and need replacing
Hope this Helps
Kind regards
Brad
Jan 02, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My chainsaw quite suddenly. i restarted it but
1. The kickback brake, if equipped, was triggered to stop the chain.
2. The chain is jammed with saw dust/debris (it doesn't take much)
3. the bar sprocket is damaged.
4. The chain guide teeth are damaged and not sliding through the bar guide groove smoothly
5. The chain is adjusted too tightly.
6. You are out of bar oil and friction has stopped it/damaged the bar and/or chain
7. The motor sprocket clutch is damaged.
That should cover all of the basics to look over.
Nov 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
2.3 ci chainsaw 16in. sparkplug size and number
Take the Plug out of the saw and read the part number.
Sep 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Oil & Gasoline
Hi Thomas, you can find bar oil for the chain at just about any hardware store. Just tell them you need chainsaw bar oil. The oil that mixes with the gasoline is called 2- cycle mix. They will have that also. You can find the 2- cycle mix at a lot of gas stations too but a lot of guys caution not to use the 2 - cycle mix that is made for outboard motors. . Hope that answered your questions.
Jul 11, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My chainsaw is not getting any oil to the chain.how can it be fixed.
First off, take off the bar and chain, clean up the grooves and the small oiling holes in the bar. Then without the bar on, start the saw, see if oil comes out of the oiling hole, if not, dump the oil out of the saw, put some gas in, rinse out well, spray brake cleaner works well, too. Refill with oil and see if its oiling yet, make sure to check if it has an adjustable oiler, open it up a bit if need be. Use only bar and chain oil, not car oil!
Jun 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
371 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
