Question about Bosch 7" Large Angle Grinder 1873 - 8
Changing the crown gear.
Is there a specific procedure for removing/replacing the crown gear from the "head" of the grinder?
2 Suggested Answers
  • 277 Answers
SOURCE: Worn gears
I would just buy a new one.
parts could cost almost as much.
don't forget the rest of the grinder is just as worn out too
Posted on Jun 24, 2010
How do I remove the gear from the gear housing assembly?
first grinding wheel > flange> safety cap > 4 screws >remove axis with drive shaft crown wheel > then 4 screws remove front with the armature if you must replace cone wheel and crown wheel. remove first the carbon brushes before take the armature out.
Dec 29, 2015 | Dewalt 4 1/2" Small Angle Grinder D28402
Need timing marks and how to adjust dual cam gear marks after removing heads
Register for free at autozone.com. List your make, model and so on, you know like so anyone knows what you got!
Repair guides specific to your car, it has timing diagrams and procedures.
Feb 04, 2014 | Cars & Trucks
How do I replace the big gear on a makita 9557nb grinder
After taking the bearig box off the head, remove the retaining ring and wave washer on top of the gear. Some spindles can be tapped out of the gear with a hammer but be extremely careful not to mushroom the spindle head. It's best to take it off with a hydraulic press. There is a woodruff key in there so be careful not to loose that when you press the spindle out of the gear. The new gear should be pressed back on also.
Dec 31, 2011 | Makita Saws
How do you remove the front rearend crown and pinion on 1997 gmc serria 4x4 1500 pick-up
That indicates a bad pinion bearing. On this rear end it is usually necessary to replace the ring and pinion gears as well as the bearings becasue when the pinion bearing goes bad it will spin on the pinion gear itself causing it to wear thus just replacing the bearing will not work because it will fit loose on the pinion gear and it needs to be pressed on tight. ---------- First the c-clips are to be removed from the pinion gears.-------- Click this link below and follow the detailed procedure:---- http://technoanswers.blogspot.com/2011/07/how-to-remove-rear-end-crown-and-pinion.html -------------- This should help.Thanks.Helpmech.
Jul 17, 2011 | GMC Sierra 1500 Cars & Trucks
How do you remove the crown gear?
The gear on the end of the armature is held on by a metric nut. The armature shaft is threaded. The larger gear is press fit onto the shaft. You need a hydrolic press to remove it.
Jul 08, 2011 | Bosch 7" Large Angle Grinder 1873 - 8
Black & Decker 4 1/2 grinder gets very hot when in use
You will see vents near the head of the grinder. Make sure your hands are not blocking when in use. Also another thing I like to do with my grinders is removed the head cover (gear box) and replace the lube with a good grade of grease. I suspect if you open yours it will look like an orange wax substance. Clean and re-lube. They do run on the warm side.
Jun 09, 2010 | Black & Decker 4 1/2" Small Angle Grinder
Wickes 9" angle Grinder Crown gear broken where to get replacement
Look on ereplacementparts.com They have everything. very good company.
Nov 15, 2009 | Saws
How to replace main bearing in a Makita GA5000 5'' angle grinder. I removed the clip in the gear head but can't remove the gear to pull the armature. The main armature bearing in the gear head is shot.
i used to grab the armature and tap the housing off with a rubber hammer...
try tapping in opposite corners every time....
when it does fall have a cushion ready on the bench or floor to catch it...
Jul 10, 2009 | Makita GA7020 Angle Grinder
Changing spark plugs on A ford Crown Victoria V-8 with coil over
Its called common sense.. Torque them in by hand.. Not too much not too little
Mar 15, 2009 | 2001 Ford Crown Victoria
Replacing the Engine Head
As long as you don't remove the timming chain & gears you won't change the camshaft timming.thank you
Jun 24, 2008 | 2001 Jeep Grand Cherokee
Bosch 7" Large Angle Grinder 1873 - 8 Logo
75 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
