Question about Uniden BC370CRS Base Scanner
My scanner bleeds over on reception from other channels
    Genius:
  • 1,274 Answers
Try turning down the squelch....hope this helps......
Posted on May 12, 2010
We unplugged our scanner to replace carpet and now we no longer get any reception
Probably the channel memory was cleared while your scanner was disconnected from power.
May 28, 2016 | Radio Communications
Cant get weather on my motorola MH370CR
Setting the Weather Channel
Your should radio receives weather frequencies if you are close enough to a reporting station:
1. After turning weather reception on, press . The current
Turning Weather Channel Reception On and Off
1. To turn weather reception on, press and hold + (plus) for three
seconds.
2. To turn off, press + or turn the radio off and then back on.
Your radio receives weather frequencies:
1. After turning weather reception on, press MENU . The current
channel flashes.
2. Press + or - to select the appropriate channel with good
reception in your area.
3. Press PTT to save the weather channel setting.
Here's a link to the MH user guide.
Best regards.
http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
Feb 02, 2014 | Motorola Radio Communications
When I press Weather/Snooze the radio emitts a high pitch sound like a whistling. I have the radio set to voice, I have verified the channel 162.4750 for my area. I have a scanner tuned to that same...
Solution #1
Some counties have two frequency channels. check this URL address to see if you have another frequency channel for your area- http://www.nws.noaa.gov/nwr/indexnw.htm. If you do, try the other frequency channel for your area.
Solution #2
You may be receiving a poor reception quality because of where the radio is located or the antenna's positioning. First play with the antenna until you get a better reception. If this doesn't help, try moving it to a location near a window or outside room. If this doesn't help, you may have to buy an external antenna from an electronics store and hook it up to your radio. If you still have your WR-100 Owner's Manual, they have a page in there for reception (page 12), and it lists in there their suggested weather radio antenna.
Solution #3
It may not be anything you've done at all. It could be the weather station's transmitter itself. May you should call your local NWS office and plea your case to them.
Sep 13, 2010 | Midland WR-100 Weather/RDS Radio
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Jun 18, 2010 | Sanyo Televison & Video
I have a bc350c 800 mhz and cant get nothing but static how to i get the police channels to work
Try tuning known frequencies, such as the NOAA weather channels, to verify the working condition of your scanner. If it picks them up, you don't have your local police system/frequencies programmed properly. If there's no reception, even on NOAA, you have an antenna or receiver problem that may need professional attention.
In case you need it, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Apr 27, 2010 | Uniden BC796D Base Scanner
Trying to program it
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
Once you have your freq list, power the scanner ON,and:
1. Press PGM. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the keys to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel. Press DELAY if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends.
4. To program the next channel in sequence, press PGM and
repeat Steps 2 and 3.
Operation
• To listen to a weak or distant station, turn SQUELCH counterclockwise. If reception is poor, turn SQUELCH clockwise to cut out weak transmissions.
• If SQUELCH is adjusted so you always hear a hissing sound, the scanner will not scan or search properly.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
BillB
Jan 09, 2010 | Radio Shack Pro-2018 Scanner
What channels for scanner
You will have to find out if your local safety systems are analog, digital, analog trunking or digital trunking, then buy the appropriate scanner. Radio Shack can at least let you know that much before you buy a unit. If they have digital trunking, only 1 or 2 models will work, and reception is quite limited.
You can also go to www. RadioReference dot Com and select Florida and your county and find out the info there. okay?
Nov 06, 2009 | Uniden BC72XLT Handheld Scanner
A blank spot in reception on my 340 while a signal is heard
First thing I would check is to see if you have the "Priority" Function set on. If it is on a PRI would be illuminated in the display. When this is on the scanner will pause and check you "priority" Channel every 2 seconds, even when it is stopped on a transmission. Turn off the Priority by pressing the PRI button while it is scanning. Se if theis helps,
elijam1@ameritech.net
Dec 16, 2008 | Uniden BC340CRS Base Scanner
Bearcat scanner bc248clt
I Need to no how to prograamed channel and scan
Sep 18, 2008 | Uniden BC248CLT Base Scanner
Reception
Simple off-channel interference, tell the scanner to skip or lock out the frequency, unless that's how it sounds on every frequency. If it does sound like that on every frequency, you may have a busted speaker, use an external speaker instead.
Mar 23, 2008 | Radio Shack Pro-2096 Base Scanner
Uniden BC370CRS Base Scanner Logo
23 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
