Lw32a23wx tv no sound or remote control operation, is it something simple or has one or more of the boards failed?
  • 10,515 Answers
Before we proceed, i would Appreciate, if you could tell me :-
1. Do you see any Picture?
2. Is there any Noise?
3. Do you see Power Light being Lit?
Let me know,so that i could guide you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 11, 2010
Just unwrapped my bose solo 15 and the universal remote worked up until I tried to set up the tv.. Now it does nothing, can't even turn on the Solo 15. I removed the batteries for about 30minutes, also I...
Try removing batteries from the remote, pressing all buttons to unstick a stuck buttton, reinstalling batteries, and testing operation. Also, something may have gone wrong when you were setting the remote to control your TV. If no corrective action works, the remote may have failed prematurely.
Dec 16, 2014 | Bose Solo 15 TV sound platform
TV sound changes by its self goes to 100 or 0 randomly remote won't work
2 questions.
1. Do any of the remote functions work, IE. channel selector, settings menu etc.?
2. How old is the TV?
Several possibilities come to mind;
The remote battery is low.
The remote sound function may be faulty( bad button switch) this is usually a matter of how much the sound switch is used.
The automatic volume control in the TV has failed. This sounds like the best possibility. Once set, the sound should maintain its level. If not, the the AVC is dead and you will probably have to get the TV assessed by a tech. If this is the problem, you might consider a new TV. Tech service is expensive and in many cases it costs so much to fix a relatively simple problem, that buying a new unit is easier and more economical.
Aug 01, 2014 | Emerson LC320EM9 32 in. LCD HDTV
The menu button, tools button and others do not work. Did I do something to lock these buttons? Power, volume, channel etc. operate properly. Less than six months old.
The remote is having problems with it circuit board or it CPU chip is failing.Take the remote aparts,take some Q tips dip it in some rubbing alchahol clean the circuit board and those - + battery circuit connections terminals.Wait like about 20 mins,than put the remote back together again.Now,all the contacts points ben cleans out.The remote should work again,not than the remote CPU is failing,sorry now the remote is garbage.Try website like Remotes.com to buy an exact remote or very close to the orignal remote.
Nov 08, 2010 | Samsung TV Remote Control
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
My remote stopped working with my television. all I need is a manual that I cannot find. for CL007 remote
Remotes are pretty simple things to fix. a few problems, tests and fixes.
1) test remote closer to device - if it works then replace batteries.
2) If some buttons fail to work that used to work - disassemble and clean muck off board and rubber contact pad.
3) remote will not work at all at any distance - use camera on phone to see IR led operation when pushing buttons on remote - could be batteries, IR led failure or ceramic resonator failure - you need test equipment to faultfind.
The only parts that tend to fail on a remote are batteries, IR LED, Ceramic resonator, and dirty/wet board/rubber contact pads
Mar 19, 2010 | Zenith ZN620 Remote Control
My apex digital converter's remote no longer works. Therefore I have no TV picture because the apex wants to be re-installed due to loss of electricity temporarily.
Mar 19, 2010 | Televison & Video
Emprex HD 3202 control panel not operating
My first thought then is that the main board may have capacitor damage that will affect the boards ability to "understand" the control signals, if you can I would have the tv looked at at a service center for damaged boards and components, might be an easy fix but might not be (new boards), The lcd panel is good that can net you several hundred dollars at a min.
peope break them all the time and a simple change out is worth several hundred dollars, vs a new tv
Apr 09, 2009 | Televison & Video
Tv popping sound when turned on
It sounds like you are hearing arcing from the FBT. The FBT should be replaced before it causes something else to fail.
Jan 08, 2009 | RCA Universal Remote Control
LGE LCD Remote Control no longer works
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) re the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Sep 08, 2008 | LG 37LC7D 37 in. LCD HDTV
F9 error
Your Microwave uses "UltraWave technology"
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
The Magnetron sells for about $78.00 and is simple to replace. Check your owners manual for limited warranty on the MAG and electronic parts.
Jun 10, 2008 | Kenmore 62622 Microwave Oven
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
