Question about Pentair 150k Minimax Ch Ng Mv Heater
I would like to convert a Pentair Minimax 150 pool heater from natural gas to propane. I have done many conversions like this on other products and usually just an orfice change.
  • 128 Answers
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
Posted on Aug 30, 2009
  • 246 Answers
SOURCE: Searching for Operating Manual for natural gas pool heater.
pentairpool.com
Posted on Sep 18, 2009
  • 990 Answers
SOURCE: E04 comes on after fan purge cycle-Pentair minimax nt pool heater
This is a fan falure code. It can mean the fan has problems (not likley if the fan goes and isn't labored) You have a sensor in your exaust (probally not this if you don't get a good start) The culperet is probally in the negetive pressure sensor. This is a 2-3 inch disc with wires going to the controls and a rubber tube going to the fan. Pull the tube from the fan and make sure the fan fitting is clear (poke with a tooth pic) Be sure their are no kinks in the hose. If the heater is 4 years old the diaprahm could be bad in the pressure sensor. Check the other things first but this is probally your problem. Good luck, hope this helped.
Posted on Jan 26, 2010
john224
  • 1378 Answers
SOURCE: should the pentair minimax pool heater be wired to line or load?
Thank you for posting your question here on Fixya.com.
Line side for a couple of reasons: First, there are more safety switches than just the pressure switch to ensure the unit shuts off prior to damaging itself. Second, and probably more importantly, removing power from the unit each time the time clock turns it off will keep erasing the temperature settings you enter. After a while that gets old for most people. Coincidentally, when pressure switched fail, they fail as open making the heater inoperable. While they could conceivably short closed and cause the situation you fear, I have never seen that in 20 years of servicing heaters.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Feb 09, 2010
Testimonial: "Thanks, Myself and A pool and a friend Pool Guy was discussing this good point about the heat settings as well. thanks."
  • 990 Answers
SOURCE: Can a Pentair minimax NT that is fitted for
Probally the easyest convertion on the market. Where your gas line comes in the heater the line loops up over and down. There are two unions on this at the base of the loop. take these apart and their is a washer in one and you replace it with the Propane washer and put back together.
Posted on Sep 02, 2010
Testimonial: "thank you. quick response"
Can Mini max ch 250 M be converted to LP
not advisable safety orfices nad gas valve and regulator to be changed then mark unit propane
Jun 15, 2012 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Can a Pentair minimax NT that is fitted for natural gas be retrofitted for Propane use
Sep 01, 2010 | Pentair Minimax NT Heater
Can the minimax natural gas be converted to propane like a laundry dryer ?
Check out this link: http://ths.gardenweb.com/forums/load/pools/msg0522222224880.html
Per this link, these are the parts that you'll need to replace:
Natural gas burner tray 472028
Propane burner tray 471931
Propane gas valve 471671
Remember to always be safe around electricity and gas lines. If you're not sure then hire a professional.
If this has helped, please give me the appropriate thumbs up! Thanks, and good luck!
Aug 15, 2010 | Pentair Pool & Spa
CAN i CONVERT MY PROPANE TO NATURAL GAS ?
Probably ... have your gas company install new jets ... should be little or no charge.
May 18, 2010 | Pentair Minimax NT Heater
Is there any difference in bottle gas heater and natural gas heater
by bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
Apr 23, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Conversion from Gas mto Propane
you should be able to buy the parts from your local pool supply place or online.
Jan 19, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
BiAnnual maint of Pentair Minimax NT Low NOx Series Pool Heater
if unit is sooting check gas supply and pressure unit is overheating and ruining its self
Sep 26, 2017 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair 150k Minimax Ch Ng Mv Heater Logo
82 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
