Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
How do I change the bottom pto oil seal? What do I have to do to remove and install a new oil seal on the pto shaft after I remove engine from the frame.
2 Suggested Answers
  • 151 Answers
SOURCE: How do i set the cam shaft/valve timing on a
align the timing marks on the crankshaft with those on the camshaft and the counterbalancer (if equipped)
Posted on Dec 27, 2009
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
Leak oil from underneith where the shaft comes out of the engine
If you look at the bottom of the engine, if you see oil on the large shaft coming out of the engine where the blade is attached, the PTO or crankshaft seal is leaking. It can be replace without taking the engine apart, but you'll need to remove the blade and adapter from the crankshaft, which can be difficult without the proper tools. You'll also have to remove the old seal, with a seal puller, or by using a couple self-tapping sheet metal screws into the outer metal part of the seal. You then would pry on the screw heads to remove the seal. Replace with a new one after cleaning out the bottom of the crankcase. Clean the PTO so that the new seal is not damaged as it is slid into place. You can use a length of plastic pipe to drive the new seal into place. Replace adapter and blade. Check oil level before use.
Oh, be sure it is not the drain plug, as it may have been left a bit loose if the oil was recently changed.
tom
Jun 17, 2012 | Measuring Tools & Sensors
How do I change a oil pump
  1. Drain the oil
  2. Remove the oil pan. You may have to lift or tilt the engine or remove frame members of the vehicle to do this, so it's probably the hardest part. Clean the gasket and seal surfaces on the engine block and crankshaft end bearings. Clean the oil pan. While you have the bottom of the engine open, inspect the cylinders for score marks and check for other anomalies such as sloppy piston bushings on the crank.
  3. Remove the oil inlet screen housing if it blocks access to the oil pump mounting bolts.
  4. Remove the oil pump. Clean the gasket/O-ring surface where it meets the engine block.
  5. Pour some clean oil into the outlet of the new oil pump (not so full you spill it when you install it). This will help it get oil into the engine more quickly on its first startup.
  6. Be sure you have the outlet gasket or O-ring in place!
  7. Install the new pump
  8. Clean or replace the filter screen assembly. Replace its O-ring and install on the oil pump.
  9. Reassemble the rest of the vehicle, using new gaskets and seals on the oil drain pan.
  10. Fill the new oil filter about 1/2 full of oil and install (always do this - it reduces the time the engine is turning dry after an oil change). This does not apply to vehicles that have open-face filters mounted in the bottom of the oil pan such as the 1980's Buick four-cylinder models.
  11. Add the rest of the oil in the usual manner.
Jun 06, 2011 | Honda CR-V Cars & Trucks
Briggs&straton all the oil leaked out from under the engine. the engine oil
hi there donald77
provided you have not got any cracks in the sump plate and the sump plate bolts are tight
sounds like you have a worn out pto seal ( please check pto for bend or wobble ) as this could have caused this from hitting something solid
it it is bent have it straightened before proceeding
remove the blade carrier and hub and key - clean up the pto with emery tape , drain oil , use a straight shaft flat blade screwdriver and lever the seal out of position
obtain a new seal place some thin plastic sheet ( from say a thin walled plastic container )
cut into a size that you can wrap around pto , then slide the seal over it up to the opening ,
the drive the seal into the housing squarely until the seal is flush with the housing ( on a non stepped pto ) 7/8 shaft
but on a stepped pto 25 mm drive it in further until its about 3 mm below the housing
reassemble and refill with oil
cheers hope it helps
pauly46
May 30, 2011 | Garden
How do I change oil and filter on bmw 5 series 1992
warm engine up then raise/jack up front of vehicle there is a 17mm nut/oil plug on the bottom of the aluminum oil pan that you will need to remove and drain into oil pan that can hold at least 7qt of oil. then from the top there is a round aluminum cover with a 13mm bolt near the front of the engine that will need to removed and the oil filter is inside that will need to be replaced dont forget to replace the seals on the cap and screw that come with the oil filter. then after oil is finished draining re-install drain plug with new seal lower car back on grond and then install new oil filter and seals then add oil 6qt. to start then start engine and run for 30 sec. wait 10sec. then check oil level and add as needed
Mar 08, 2011 | 1992 BMW 5 Series
2002 Pontiac Sunfire GT. 2.2 Litre Ecotec Engine. Concern: Front Seal is leaking. Question: Does the engine need to be pulled to replace the seal?
No. The crankshaft pully can be removed through the right wheel well area. (This is the hard part) Once the pully is off, the seal is relatively easy to change.
Jan 25, 2011 | 2003 Chevrolet Cavalier
Oil Is Leaking Out Under The Harminc Balancer On my 92 Jeep Wrangler,4.0 6cyl. I Replaced The Main Seal & Put A New Balancer On & It Still Leaks From The Bottom Of The Balancer
  1. timing cover is leaking oil betwwen cover and block
  2. Disconnect the negative battery cable.
  3. Remove the drive belt(s), fan and fan shroud. If equipped, remove the accessory drive belt pulley.
  4. Remove the vibration damper retaining bolt and washer. Remove the vibration damper using a suitable puller.
  5. Remove the accessory drive brackets attached to the timing cover.
  6. Remove the A/C compressor, if equipped, and alternator bracket from the cylinder head and move to one side.
  7. Remove the oil pan-to-timing case cover bolts and the cover-to-cylinder block bolts.
  8. Remove the timing case cover front seal and gasket from the engine.
  9. Cut off the oil pan side gasket end tabs and oil pan front seal tabs flush with the front face of the cylinder block. Remove the gasket tabs.
  10. Clean the timing case cover, oil pan and cylinder block gasket surfaces.
  11. Remove the crankshaft seal oil seal from the cover by prying it out with a suitable tool.
To install:
  1. Install a new seal in the timing cover using a suitable seal installation tool.
  2. Apply sealer to both sides of the replacement cover gasket and position the gasket on the cylinder block. Cut the end tabs off the replacement oil pan gasket corresponding to those cut off the original gasket. Attach the end tabs to the oil pan with sealer.
  3. Coat the front cover seal end tab recesses generously with sealer and position the seal on the timing cover.
  4. Apply engine oil to the seal-oil pan contact surface, then position the cover on the cylinder block.
  5. Insert timing case cover alignment tool J22248 or equivalent, in the crankshaft opening. Install the cover-to-cylinder block bolts and tighten them to 62 inch lbs. (7 Nm). Install and tighten the oil pan-to-cover bolts to 11 ft. lbs. (13 Nm).
  6. Remove the cover alignment tool and position a replacement oil seal on the tool with the seal lip facing outward. Apply a light coat of sealer to the seal and a light coat of oil to the crankshaft. Install the seal on the timing cover.
  7. Apply a light film of oil to the vibration damper hub seal contact surface. Install the vibration damper using a suitable installation tool.
Do not hammer the damper into place as damage may result to the damper or engine.
  1. Install and tighten the crankshaft vibration damper bolt to 80 ft. lbs. (108 Nm).
  2. If equipped, install the crankshaft pulley and tighten the bolts to 20 ft. lbs. (27 Nm).
  3. Install the accessory brackets.
  4. Install the fan and fan shroud.
  5. Install the drive belt(s) and adjust to the proper tension.
  6. Connect the negative battery cable.
  7. Start the engine and check for leaks
  8. .
Jan 18, 2011 | 1992 Jeep Wrangler
How to repair front crankshaft seal leaks oil
Need to get at the crankshaft seal, usually by removing the crankshaft pulley and using a seal remover to take out the old seal, then put a new seal in.
Here are some instructions on how to do the 'rear' seal:
Rear Main Seal Removal & Installation 2.4L, 3.3L & 3.8L Engines To Remove:
  1. Remove the transaxle and flexplate. CAUTION
    Make sure not to damage the crankshaft sealing surface when removing the oil seal.
  2. Insert a flat-bladed pry tool or equivalent through the dust lip at an angle.
  3. Carefully pry the oil seal out of the engine. Pry against the chamfered edge of the crankshaft, do not damage the sealing surface of the crankshaft or an oil leak may occur.
To Install:
CAUTION
Smooth any burr or rough edge on the crankshaft with 400 grit sandpaper to prevent seal damage during installation.
NOTE: When installing seal, no lube on seal is needed.
  1. Place special tool 6926-1 seal guide or equivalent on crankshaft.
  2. Place the seal on the guide. Make sure the seal lip is facing the crankshaft and the guide tool remains on the crankshaft. Rear crankshaft seal installation (2.4L engine shown, 3.3L & 3.8L engines similar) chry-03-24-827.gif
    CAUTION
    Do not drive the seal into the block past flush. An oil leak may occur.
  3. Drive the seal into the block using a seal driver or special tool 6926-2 and handle C-4171 until the tool bottoms out against the block and the seal is flush.
  4. Install the flexplate and transaxle.
3.0L Engine To Remove:
  2. Remove the oil seal with housing from the rear of the engine block.
  3. Remove the oil seal from the housing.
To Install:
  1. Clean the sealing surfaces on the seal housing and engine block.
  2. Use a commercial seal installer to install the seal in the seal housing.
  3. Apply a light film of motor oil to the seal lip.
  4. Apply silicone sealant to the oil seal housing sealing surface and install the housing with seal on the engine block. Tighten all bolts to 104 in. lbs. (12 Nm).
  5. Install the flexplate and transmission.
Dec 31, 2010 | 1997 Plymouth Voyager
I have a 2006 Pontiac Grand Prix, it is supercharged 3800. I have about 115,000 miles on it and I change the oil every 3,000 miles, check fluids, regular preventative maintenance, etc. I noticed a small...
If it's oil, it's coming from the rear main seal.. I would go with this idea.
The seal doesn't cost much but the labor to get to it does.
To give you an idea what is involved the procedure is illustrated below from the service manual:
Removal & Installation 3.8L Engine To Remove:
  1. Drain the engine coolant.
  2. Drain the engine oil.
  3. Remove the oil pan.
  4. Remove the engine flywheel.
  5. Remove the rear oil seal housing and gasket. Rear seal removal 3.8L gm-03-38-1175.gif
  6. Remove the rear main seal by placing the housing face down on 2 blocks of wood. Using a drift tool and hammer tap the seal out of the housing.
To Install:
NOTE: Do not lubricate the rear main oil seal or the installation tool. Do not touch the sealing lip of the rear main seal once the protective sleeve is removed.
NOTE: Use a clean lint free cloth to clean the crankshaft sealing surface. Remove sharp edges or burrs that could damage the rear main oil seal. Remove burrs or sharp edges with a crocus cloth.
  1. Carefully remove the rear oil seal from the protective sleeve.
  2. Install the oil seal onto the seal driver EN-47623 or equivalent by placing the seal at an angle and twisting until it is fully seated.
  3. Install the seal into the housing using the seal driver EN-47623 or equivalent and driver handle J-8092 or equivalent. Apply downward force until the seal is seated. NOTE: Ensure that the housing gasket is installed correctly and that the oil passages are not blocked.
  4. Using a new gasket Install the rear oil seal housing on the engine being careful not damage the rear main seal. NOTE: The plastic inserts are used in production and are not needed for assembly.
  5. Hand tighten the bolts. Rear seal housing alignment 3.8L gm-03-38-1176.gif
  6. Place a straight edge on the crankshaft rear oil seal housing flange and the engine block oil pan flange. Using a feeler gauge check that there is no more than .0004 in (0.10 mm) step on each side. Rotate the housing to make the steps equal on both sides.
  7. Tighten the housing bolts 11 ft-lb (15 Nm) plus an additional 50 degrees.
  8. Ensure that the housing did not move out of specification. Repeat step 6 if the oil seal housing is not within the specified range. Replace the rear oil seal housing if the specified measurement can not be reached.
  9. Install the flywheel.
  10. Install the oil pan.
  11. Fill the engine oil and the cooling system.
  12. Check for leaks
5.3L Engine To Remove:
  1. Remove the flywheel from the crankshaft.
  2. Remove and discard the crankshaft rear oil seal from the rear cover.
To Install:
  1. Use clean engine oil to lubricate the outside diameter of the crankshaft rear oil seal and rear cover oil seal bore.
  2. Install the tapered cone and bolts of a J 41479 or equivalent crankshaft rear oil seal installer onto the crankshaft.
  3. Place the crankshaft rear oil seal onto the tapered cone.
  4. Install the threaded rod of the J 41479 crankshaft rear oil seal installer into the tapered cone. Rear main seal installer 5.3L gm-03-53-3872.gif
  5. Install the crankshaft rear oil seal by turning the handle of the J 41479 clockwise.
  6. Remove the J 41479 crankshaft rear oil seal installer from the crankshaft.
  7. Install the flywheel onto the crankshaft.
prev.gif next.gif--- I'm not sure what the exact cost would be as the hours were not listed for this procedure on my online resource.
Sep 02, 2010 | 2006 Pontiac Grand Prix
When changing the trans fluid on my 2004 Avalanche, I understand that you have to disconnect the trans lines from the radiator and run the engine until the fluid stops flowing. Is this correct? If so, do...
I didn't read about running the engine at all during the transmission fluid change. --- Removal & Installation 4L60E/4L65E To Remove:
  1. Raise and safely support the vehicle.
  2. Place a drain pan under the transmission.
  3. If equipped with a drain plug, drain the transmission fluid.
  4. If necessary, remove the bolts and position aside the range selector cable bracket for clearance while lowering the pan. It is not necessary to remove the cable from the lever or bracket.
  5. Remove the catalytic converter.
  6. Remove the oil pan bolts from the front and sides of the pan only.
  7. Loosen the rear oil pan mounting bolts about 4 turns.
  8. Lightly tap the oil pan with a rubber mallet in order to loosen the pan and allow the fluid to drain.
  9. Remove the remaining oil pan bolts.
  10. Remove the oil pan and the gasket.
  11. Remove the filter by twisting and pulling on it.
  12. Remove and discard the filter seal. The filter seal may be stuck in the pump; if necessary, carefully use pliers or another suitable tool to remove the seal.
  13. Clean the transmission and the oil pan sealing surfaces with solvent, and air dry. You must remove all traces of the old gasket material.
To Install:
  1. Coat the new filter seal with transmission fluid.
  2. Install the new filter seal into the transmission case. Tap the seal into place using a suitable size socket.
  3. Install the new filter.
  4. Install the oil pan and new gasket. Tighten the bolts alternately and evenly to 97 lb in (11 Nm).
  5. Install the catalytic converter.
  6. If previously removed, install the range selector cable bracket and bolts. Tighten the bolts to 18 lb ft (25 Nm).
  7. Apply a small amount of sealant GM P/N 12346004 (Canadian P/N 10953480), or equivalent to the threads of the oil pan drain plug, if equipped.
  8. Install the oil pan drain plug, if equipped. Tighten the plug to 13 lb ft (18 Nm).
  9. Lower the vehicle.
  10. Fill the transmission to the proper level with DEXRON® III transmission fluid.
  11. Check the COLD fluid level reading for initial fill only.
  12. Inspect the oil pan gasket for leaks.
4L80E/4L85E To Remove:
  1. Raise and suitably support the vehicle.
  2. Place a drain pan under the transmission oil pan. Drain the transmission fluid and install the plug. Tighten the drain plug to 13 lb ft (18 Nm).
  3. Support the transmission with a transmission jack.
  4. Remove the transmission crossmember.
  5. Disconnect the range selector cable end from the transmission range selector lever ball stud. NOTE: It is not necessary to remove the selector cable from the bracket.
  6. Remove the transmission range selector cable bracket. Reposition the bracket and cable.
  7. Remove the oil pan bolts. NOTE: The transmission oil pan gasket is reusable. Replace as needed.
  8. Remove the oil pan and gasket.
  9. Remove the magnet from the bottom of the pan, if necessary.
  10. Remove the oil filter and neck seal.
To Install:
  1. Clean the transmission and the oil pan sealing surfaces with solvent.
  2. Install the filter neck seal and filter.
  3. Install the oil pan gasket to the pan.
  4. Install the magnet into the bottom of the pan, if necessary.
  5. Install the oil pan and bolts. Tighten the oil pan bolts to 18 lb ft (24 Nm).
  6. Install the transmission range selector cable bracket. Tighten the bolts to 18 lb ft (25 Nm).
  7. Connect the range selector cable end to the transmission range selector lever ball stud.
  8. Install the transmission crossmember. Tighten the fasteners to 70 lb ft (95 Nm).
  9. Install the transmission mount nuts. Tighten the nuts to 30 lb ft (40 Nm).
  10. Remove the transmission jack.
  11. Lower the vehicle.
  12. Fill the transmission to the proper level with DEXRON® III transmission fluid.
Aug 26, 2010 | 2004 Chevrolet Avalanche
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
374 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
