Question about Sony VAIO VGN-CR220E/P Notebook
Sony Laptop no power
Hello, holding down the startup button and can't get it to turn on. think it may be the adapter because it was plugged in but not charging right before it went blank.
    President:
  • 3,278 Answers
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on May 11, 2010
Black screen on startup
If your laptop is making all the usual noises but has a black screen try pulling the power adapter out and battery then hold down the power button for 30 seconds, plug in the main adapter again and turn it on.
"fingers crossed"
Nov 23, 2012 | Sony VAIO VGN-X505 PC Notebook
My Dell Latitude D620 laptop will not boot up unless I hold the power button down. The computer will run fine if I keep holding the power button down. It will also keep running if I hold down any key. As...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
Hope this helps.
Oct 04, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
My laptop is not starting up. The Startup repair is undergoing for hours.
Remove the dc battery, and unplug the dc adapter.You will hold or press the power button for 40 seconds.Now you will get positive result,when you plug the adapter to your laptop and the Battery also.Almost 80% laptop can solve for this problem through the process.Its a restore process.
Hope it help you.
Jan 10, 2011 | Toshiba Computers & Internet
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
I turn on the power, the power light comes on and the hard drive light for about 3 seconds than off...and i never get a screen. what could be the problem
Hello
First Remove all power (adapter power Cord and Battery (for laptops))
Hold down the ON button for 30secs (dispersing internal voltage)
Plug the power cord in only (ie leave battery out, for the moment)
Turn on
If it worked replace battery.
If it doesnt
Start your computer and press down on the "F8" key to get into the "Advanced Boot Options" menu.
Click the "Repair your computer" option on the menu and press the "Enter" key.
Select your keyboard layout from the choices given.
Click the "Next" button to enter the "System Recovery Options" menu.
Choose "Startup Repair" from the menu and press the "Enter" key to start the repair on your startup disk.
Dec 15, 2010 | Toshiba Satellite A135-S2386 Notebook
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
Vaio sat survey has stop working
Do the following:
-unplug adapter from the wall
-unplug from the computer side
-remove the battery
-With everything unplugged and battery removed, press the power button.  Keep holding it down for 15 seconds
Yes, nothing happened, that is ok. :)
-re-insert the battery first
-plug the adapter to laptop side first
-plug adapter to wall socket
Now, turn on the laptop and see if it powers on.
Jun 28, 2009 | Sony VAIO VGN-CS118E/P NoteBook
When i try to turn on my macbook nothing shows up on the screen and the white light on the bottom right turns on and stays on
Plug the power adapter in. Then hold down the startup button for 15 seconds. The light should go off and then after a few seconds. restart normally. The macbooks have a safety device that will lock up the drive if it detects sudden movements to protect the drive...
Let me know if you're back up and running. KEN
Apr 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Sony VAIO VGN-CR220E/P Notebook Logo
128 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
