Question about Rockford Fosgate Punch 500a2 Car Audio Amplifier
My Sub Doesnt Sound Good
I bought my PUNCH 500-a2 amp from my brother and im not sure what I should have the settings on.
  • Thomas Capo
    Thomas Capo Apr 01, 2008
    thank you these settings work good.
    Novelist:
  • 100 Answers
The settings are all pretty much dependent on your ear. But some guide lines would be for the input gain, never turn it all the way up. Turn the gain up about half way possibly 3/4 of the way up. There should also be a filter, if you are powering subs then you want to filter out any high frequencies. So if there is a switch saying HPF or LPF you want LPF (Low Pass Frequency). Then there should be another "knob" that controls the frequency. At the least, you want your sub amp to be tuned below 50 Hz any lower is up to your ear. I hope this helped.
-Andrew Hawkins
Posted on Mar 29, 2008
Hi i have a few questions. I have bought a dual 12 " sub box and i need 2 subs and one amp to go with it. I want intence base that will impress! I am currently looking at 2 Alpine SWR-12D4 they are...
It's been my experience,that intense and low bass comes with a price,always remember u get what u pay for,so on that note,Try to get Rockford Fosgate Competition subs with a punch 250 or 500 trust me that it is a powerful combination.and if u can afford it get a choke to put on ur subs so they will only kick bass put tweeters in the dash and mid range speakers in the door u could use a dual rca jacks to install 2 amps at once and get a punch 45 amp for the tweeters and mids.hope this was helpful
Apr 03, 2013 | Car Audio & Video
I have a boss cx-3500 amplif & and a rockford p2 15 inch sub & not much punch what can i do to have more punch
mess around with the frequency on the amp till you get a good heavy loud sound and turn up the bass more and make sure the speaker cables are in the correct ports if one is in the other the wrong way around it wont give out as good quality or bass
Aug 20, 2012 | Rockford Fosgate Car Audio & Video
I just bought a punch 500 a2 amp. i hook up my ground, then try to hook up the power cable and it sparks. my punch 250 was hooked up minutes prior to this so i know my wiring is good. what the heck is the...
The spark could be from the capacitors in the amplifier charging. Make sure the main fuse from your battery is still good and also check all the fuses on the amplifier. Verify all the wiring is correct and make sure none of the wires from inside the positive cable are poking out and touching the vehicle or amplifier chassis. If you have a 1k ohm resistor, you can put it in series with the amplifier power line to slowly charge the capacitors. You can do that by following the directions from the link below. After doing all that, remove the 1k resistor, hook it all up and try it again. If it still doesn't work, make sure your remote wire coming from the head unit has a voltage on it when the head unit is on. You can get a cheap volt meter from a hardware store or wal-mart.
http://www.ehow.com/how_7203337_charge-capacitor-car-stereo-system.html
May 21, 2011 | Rockford Fosgate Punch 500a2 Car Audio...
Got a brand new dsw pro 500 and hooked it up to a new pioneer elite receiver through the LFE input. LFE and subwoofer are turned on but the sub does not make sound.... whats up?
if there is multiple jacks on the sub be sure they are hooked up correctly simple mistake if not no doubtly a simple overlooked setting on your amp good luck you will get it
Nov 20, 2010 | Polk Audio DSW PRO 500 Subwoofer Speaker
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Something Wrong With my Fosgate 500-a2 Amp
Is the amp being fed directly from the head unit's RCA preamp outputs or is it being fed by another amp's preamp outputs? Try temporarily wiring up a speaker you know is good in place of the sub and see if anything changes.
Apr 01, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Sub doesnt sound loud
try to change subs with your friend to find out if the problem is on amplifier or on sub wofer
Nov 21, 2007 | Q-Logic QLT-.3508SS Car Subwoofer
Rockford Fosgate Punch 500a2 Car Audio Amplifier Logo
134 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
