I have a Toshiba LCD 42HL167 2007 model. After 20 to 30 mins being on it loses video intermittently.
  • Patrick McAlexander May 12, 2010
    I've tried all inputs with different devices. Same thing.
    Thank you
  • 4,234 Answers
An experiment is called for here for confirmation. The system will take video input and process it for display. The MENU is generated internallty and inserted into the viodeo stream later down stream from the processed input. Can you test to see if you get get the menu up after the video quits? This will help to narrow down the problem area to either the dispaly area or the processing area.
If the unit is less than 1 year old, take the results of the above experiment and provide that to the servicer. Otherwise, please update this and we'll proceed to the next step depending upon the results.
Thanks,
Dan
Posted on May 12, 2010
  • 6,993 Answers
I suspect the TV bulb. How long have you been using the TV and have you ever changed the bulb? Usually when TV bulb needs replacement, the TV visual will not be clear.
Also, if your TV is connected to a cable box, I would advice that you check the video cord that connects the cable box or DVD player to the TV. The video cord might be loosing contact.
Good luck.
Posted on May 11, 2010
    It loses video and audio on ALL inputs from different devices. No bulbs have been changed. I get light on the raster. Connections are good.
Need to know the size of screws that goes into TV stand for a Toshiba TV model number 40S51u
58 cents each mail order. Not only do they have to be right diameter and thread, also the correct length.
40S51U Toshiba Tv, 40" 1080P Led Lcd Replacement Parts
https://www.encompassparts.com/model/TBA40S51U/_/_/Toshiba/40S51U/Tv,_40
  1. Cached
Toshiba from Encompass parts & accessories. ... 40S51U Toshiba Tv, 40" 1080P Led Lcd. 40S51U Tv, 40 ... 75024004, Toshiba Screw, Stand, Mac000, 0.77.
Toshiba 40S51U Parts List - PartStore.com
https://www.partstore.com/Model/Toshiba/Toshiba/40S51U.aspx
  1. Cached
  2. Similar
List of Spare Parts for Toshiba 40S51U Parts List. 40S51U UNKNOWN ... Toshiba TV Mounting & Installation. 75024004. SCREW, STAND, MAC000. $0.58.
Toshiba TV Stand for 40S51U Complete with Neck and Screws ' eBay
www.ebay.com > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
TOSHIBA TV STAND FOR 40S51U COMPLETE WITH NECK AND SCREWS in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Parts ' eBay.
Toshiba TV model number 40S51u Google Search
Nov 27, 2016 | Toshiba Televison & Video
Insignia LCD TV loses power
Probably it is a faulty power board.
Oct 06, 2008 | Insignia 37" LCD Flat-Panel HDTV
I have a Toshiba L555D-S7005 lcd goes blank intermittently - I think it is the LCD inverter going bad, but I am uncertain. I have been trying to find the part number for the inverter, but I am having no...
I recommend that you try updating the video driver and check the operation. You may also try using the computer in safe mode and check the operation. Any issues with the video driver will cause the issue with the display. If it is not working, to confirm that the issue to be hardware, you can try a system recovery. If re installing the operating system does not resolve the issue then you need to get the unit serviced.
You can the model specific informatioon and the drivers here:
http://support.toshiba.com/support/modelHome
Sep 08, 2013 | Toshiba Satellite P100 Notebook
My 47LG50 is just over 2 years old, about 30 days ago I started to lose the video/picture At first it happeded every once in a while, now it is every 5-8 minutes. I can turn it off and turn back on and it...
This problems it could be those 2 long LCD inverter boards are dead,so it is not giving ur tv LCD screen panel the backlight to produce a picture or the tv Tuner signal board itself is the problems it dead.That the board,that take in the incomming broadcasting signal wire ur case the HDMI or Component cables.Take out the incomming broadcasting signal to the tv,turn on the tv,now tv have no picture,it should have a loud white static picture noises for good more 5-8 mins,than problems it not the tv Tuner signal board.Than it is those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes 2 long inverter boards or the tv Tuner signal board for the replacement.
Mar 25, 2011 | LG 47LG50 47 in. LCD HDTV
Mw27h62
X-box Sounds like it could be a bad inverter board, Toshiba p/n#72001911 and they cost about $35 plus shipping... This is a common failure with this model causing anything from intermittent shutdown to simple loss of video. Get it in the shop and have them check it out. Might also take the part number with you so they don't have to research it... Good Luck Bill
Jun 08, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
