Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
The refrigerator unit temperature does not go down
I have a Samsung refrigerator RS2666SL moedel that I bought about 5yrs ago. The freezer unit is working but refrigerator unit is not. the temperature is set for 34 but the actual temperature is above 50 and it doesn't get lower. I tried unplugging it for a day and plugging it back and it still doesn't work.
  • 1,284 Answers
Hi, check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coil (under the unit) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer, there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem, you can check the defrost terminator, defrost heater and the defrost timer or adaptive defrost control if used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked..
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Take care
Posted on May 11, 2010
  • parkjy2010 May 11, 2010
    then do i have to change some part in order to fix this problem?
  • Shehu Pro
    Shehu Pro May 11, 2010
    Yes, you have to change but it has to follow the due process i gave to you. Check one after the other before making any fix...
Just bought a Dometic DM2862 fridge. Freezer on goes down to 12 deg. and lower unit down to 38 deg., but during day the temps are: freezer - 22 deg. and lower - 44 deg. Is this normal? Can I fix this?
While there is some fluctuations in temperature in Dometics from night and day, but it is usally the reverse of what you state. Warmer in the day time when the unit is opened more. I would check the temperature settings and if they are correct then check the thermostat.
Aug 31, 2011 | Dometic RM2652 Refrigerator
Frost in top freezer - water leaking in refrigerator - ice maker not working
go through this link it will help you
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Oct 08, 2008 | Frigidaire FRT21HS6D Top Freezer...
I have a RFG297ACRS (Canadian Model of AARS). Bought new and delivered yesterday. Waited 2 hours before plugging it in as directed by the delivery guys. Plugged in 24+ hours ago but until now it's still...
must be on demonstation mode, manual says the following: press ENERGY SAVER BUTTON AND FREEZER/HOLD 3 SEC FOR POWER FREEZER BUTTON simultaneously for 3 seconds until an alarm sound is heard.
Jan 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Samsung silver nano freezer fan blades broken due to ice build up. need new blades. Please tell me where can I get Them. And how to stop it happening again.
Samsung silver nano 5yrs old - trips main electrics - 13A fuse ok but everything trips when the fridge/freezer is switched on
Aug 14, 2010 | Samsung Refrigerators
I bought refrigherator 5years ago. model no. is RS2666SL. Then today the freezer stopped working and everything just melted. I ajusted the freezer's tempature to -6 and the light started blinking. What can...
try and unplug the unit for awhile and plug it back in there is a chance the main control board is bad or the compressor has gone bad. is there any cold air at all.or ice build up on the back of the frezzer compartment,?
May 18, 2010 | Refrigerators
My samsung refrigerator model RB1855SL is experiencing a temperature sensor issue. The freezer target temp is set to zero degrees and the refrigerator to 38. The unit cools itself down to the target...
We've had tonza problems with ours too, kept building up frost, temperature sensor acted up as well. Piece of trash if you ask me. Never fixed it (did not want to throw money at it). Amazingly we just got a new one... another Samsung.... (with 4 yr extended warranty though this time!)
Oct 13, 2009 | Samsung Refrigerators
The freezer light is blinking -4
according to the service manuel a blinking light indicates a sensor failure in the section in your case the freezer side but don't panic the unit has an emergency run mode which will keep things at set value till the unit is check in other words like it is now this is a complicated unit so id call for a factory authorized tech to come and check it
Jan 14, 2008 | Samsung RS2556 Side by Side Refrigerator
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
My Amana AFD2535DEW freezer problem
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Oct 16, 2007 | Amana AFD2535DES French Door Refrigerator
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
97 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
