When my WinXP system turns off the dsiplay after the specified idle time, my Samung 2220WM monitr does not go to a power save mode but continues to display the floating "Check Signal Cable" message. I have the latest Samsung driver. Any know how to fix this?
SOURCE: green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
The problem I have is that when we connect the screen it wiorks fine then blacks out after 5-40min
It then flickers on and off iregularly and every now and then shows distortion and eventually just blacks out
I have two 172N monitors and both now show the same symptoms
We have used different VGA cables and different computers in different locations all with the same result
There is no external influence that we know
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
SOURCE: i have a samsung 17''
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
