Question about HP PhotoSmart C4480 All-in-One Printer InkJet
My printer is printing grey instead of black on my Mac. It was fine, but now I can't figure out what's wrong. Ink levels are good. I did accidentally get water in the AC adapter. Could that be it? After this happened, I printed somethind in Adobe's InDesign and it was black until I scaled the page to fit the page for printing. That's when all blacks went to light grey in every program. Could only get it to print black again in Indesign when I clicked the "print black text"box. Only worked once. Did I fry my printer with water or change some setting when I printed the spread in Indesign?? Help
  • 412 Answers
No, the water has nothing to do with it. Somewhere in a print dialog or perhaps in the printer driver, something changed to grey.
Try printing an ordinary black text document. Before you click "Print", look for "properties" or "Printer setup". Somewhere in there something got changed. Perhaps you can find a "default" button in a dialog box to restore the printer to factory settings.
MIGHT help (probably not) to shut down the Mac, power down the printer, and then start both up. Just an idea.
Posted on Apr 19, 2017
5 Suggested Answers
  • 27 Answers
SOURCE: InDesign Printing problem; service error 49.4c02
This is a solution which has been suggested on another site, this has not been tested by myself so no promises.
1. Turn the printer off.
2. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
3. Remove all EIO devices from the printer.
4. Turn the printer on.
5. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
6. Replace a DIMM or EIO device if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
Hope it helps, as I said, not tested personally.
Posted on Jun 19, 2008
  • 3866 Answers
SOURCE: Printer won't print in black ink.
Plunger needs to be cleaned, print head also would need to be looked at on this one.
Posted on May 21, 2009
  • 145 Answers
SOURCE: Printer won't print black
When you go to print check to see in your print preferences settings to see if color or black and white is checked. Could also be the specific program's print options you are using to print the pages.
Posted on May 25, 2009
SOURCE: HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Posted on May 06, 2010
How do you fix the colour printing grey instead of black
Do you need to change out your black color cartridge? Check your ink levels to make sure that you have plenty of each color. Also, check the settings for your printer (perhaps under "properties") and make sure that you haven't clicked on "grey scale". I hope that this helps.
Jul 15, 2014 | Xerox Phaser 7400/N Printer
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
What's wrong when my phaser 6360 prints grey instead of black and I just replaced the black ink and it still prints grey
I had this, had to call service engineer who re-fitted a loose circuit board inside printer. Not sure which one because I was not here at the time. If you are confident enough, and want to look for this yourself and push in all boards - be sure to disconnect from electricity supply first.
Feb 19, 2010 | Xerox Phaser 6360 Laser Printer
When i print a black and white picture from computer it prints pinkish
Have you checked your ink levels? There is a low ink utility with HP printers that should read the ink level of the Black or Grey cartridge.
If the levels are up, then run the maintenance and nozzle check for this printer through the Print menu.
Jan 14, 2010 | HP Officejet 6310 All-In-One InkJet...
Too much green
Printing too green is a sign of low or no Magenta ink. Might pay to look there. (Green is Cyan and Yellow ink, so Magenta is missing to make Grey/Black)
Sounds like someone might have also managed to mix up an ink cartridge and put it in the wrong slot?
Check that the nozzle patterns for each colour are in the right place on the print out according to the sample in the manual / online. Maybe Magenta is missing altogether?
Apr 21, 2009 | Canon i860 InkJet Photo Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Epson 1400 wet black blocks of ink output
When this happen it means that your Fuser assembly and printer interior has toner contamination and build up. You can replace your fuser or run some more test print. Usually, the printer corrects itself.
Jul 26, 2008 | Epson Stylus 1400 InkJet Photo Printer
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
268 people viewed this question
Ben Johnson
