Gateway laptop speakers
Recently my speakers on my gateway laptop model:MT6821 just started making this clicking noise over and over muting the sound and turning it all the way down does nothing im thinking it could be blown or something but idk im not a very technical person. it is also coming out of the right side only. Also the sound still works out of both side but the clicking never goes away,
  • Linksys187 Apr 02, 2008
    this worked for a little bit but then they started making the noise again even though i had removed the driver used with my audio system.
  • 5,568 Answers
Problems of this kind CAN be caused by a driver that has been scrambled by Windows.
Try the following, it may not help but won’t get you in any worse condition than the one you are in.
- Open the Control Panel
- Select System
- Click on the Hardware tab
- Select Device Manager
- Find and open Sound, Video and Game controllers
- Find the driver (check manual) used with your audio system and delete it (remove)
Reboot your system and, if there is nothing else amiss, it will ‘find’ a 'new' device and re-install the software controlling your on-board audio.
If this doesn’t help, then you are likely dealing with a hardware problem that only Gateway can (at excessive cost) ‘cure’ by replacing the main board.
Posted on Mar 28, 2008
  • Steve Allison
    Steve Allison Apr 03, 2008
    I'm afraid the latter possibility is in play; typically, notebook audio is a part of the main board (expensive notebooks often have replaceable boards for upgrades) so you only option is to call Gateway and see if they are willing to give you an estimate on the repair.
    My experience says you should be sitting down when you do this, unless they have changed a lot, they are just not that interested in repairing their failed stuff and will charge accordingly.
    Sorry that refreshing the driver didn't help-
Gateway mt6707 no sounds
Check the Mute button, make sure it is not selected.
If it still does not work then install the latest audio driver.
You can download the audio and device drivers for your model Gatewaylaptop from this WEB site. Make sure you select your model laptop and thecorrect Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Mar 14, 2012 | Gateway MT6707 Notebook PC
Hi. I'm looking for gateway mt6821 bios password recovery tool. i forget my password
Just go into safemode then just reset your password through there
Mar 06, 2011 | Gateway MT6821 Notebook
How do you replace a broken hinge on a gateway mt681 laptop??
This is listed on the Gateway support website in this pdf- http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 26, 2010 | Gateway MT6821 Notebook
Hello, i cant hear the microphone over the speaker
Make sure your microphone is not muted in the control panel, under sounds.
Nov 20, 2009 | Gateway Computers & Internet
Gateway NV52 Laptop charger sound.
I don't know if this will work with Vista but in Windows 7 you can go to the speaker icon in the taskbar and click on the icon above the volume control. This will take you to the sound properties. Click the levels tab and mute the PC speaker. This worked for me.
Oct 14, 2009 | Gateway Computers & Internet
Gateway- built-in laptop Speakers not working
Heat dissipation from the unit in the same area of the speaker assembly, especially since you stated that the RIGHT speaker was smoked. Similar problems occur with this design flaw with any manufacturer as HP has the same problem with some of their models.
Your heat exhaust is killing the speaker, and I would also bet that your chipset is AMD and not Intel, the latter having solved it's heat dissipationn problems.
A more aggressive heat dissipation solution on the motherboard or redirection of the exhaust past fewer heat sensitive components would be a design goal.
Mar 29, 2009 | Gateway MX6453 Notebook
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Gateway mt6821 power jack
The gateway document describing how to take that laptop apart can be found here. However, I'll just warn you that this is not an easy task, and sometimes the force of ripping the ******** the board ruins the board connections in that area and it will not fix it to get a new jack. This is rare, but know that it could happen.
Jan 17, 2009 | Computers & Internet
Computers & Internet Logo
593 people viewed this question
David Payne
David Payne
