Question about Fuji FinePix F47fd Digital Camera
No programs available to use in the program box!!
When I connect the camera to the pc I get the box that comes up with programs to use to get the photos to the pc but there is nothing in the box. The media xd card I have in the camera wont read through my card reader either.Help, im pulling my hair out here!!
  • 28 Answers
F47fd is PTP Camera, actually you can download your photos without using any software.
1. connect your camer to you computer and turn the camera on, you will see "USB" on your camera screen 2. Double click on "my computer", you will find a camera icon on your screen may called finepix F47fd
3.Double click on that icon, your photos will be in there.
Posted on Apr 04, 2008
Hello. I lost program for transfering to pc/
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Whether you connect via USB or use a card reader, you can also use any photo cataloging program. iPhoto comes with Macs, Windows Photo Gallery comes with Windows. There are additional programs available, such as the free Picasa ( http://picasa.google.com ).
Sep 20, 2011 | Olympus Camedia D-540 Zoom Digital Camera
How to connect to remote camera
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: 192.168.1.101. You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Jul 13, 2009 | HP USB Web Camera
Canon SD100 Powershot Can't download pics
You may have accidently removed the photo programs you were using. Check to see if the software programs are indeed still on your computer by searching by name. If it or they are there , open one of the programs before you connect the camera and it should automatically download.
If they have been removed use the disc that came with your camera to reload the software program.
Apr 13, 2009 | Canon PowerShot SD100 / IXUS II Digital...
Where is the built in photobooth program on a HP Pavillion 6910
Photobooth is a Mac Program, it runs under OS X for windows. It is not available for PC computers. There are many other programs available for the PC but photobooth is not one of them, sorry photobooth is fun but not available.
Mar 21, 2009 | HP Pavilion dv6000z Notebook
Will not let me down load
if you are hooking your camera directly up to your pc it will look for the software program to pull pictures off with... if it is not on the pc then hooking camera directly to pc will not work.
it should have come in your box with camera and i think mine said install first before hooking camera up to pc.
but the program is called EOS Utility
Dec 27, 2008 | Canon EOS Digital Rebel XS / 1000D IS...
Have a new camera...no idea how to use! Have USB cable attached to hard drive but don't know how to proceed to store pictures taken on hard drive.
Hi, does your pc have a photo program, this should detect the camera connection.
If not there are various free programs available on the internet,
I use Picasa2 you get this on google.
Download this & then connect your camera it will do the rest.
Jun 11, 2008 | Cameras
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Fuji FinePix F47fd Digital Camera Logo
106 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
