Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart am14c water keeps spraying even with power off
Hobart am14c water keeps spaying with power off i have turned water off and back on
It looks like it was the fill cycle valve was stuck on I left the water off for 10 minuets and it reset itself
Posted on Mar 30, 2008
  • 640 Answers
The internal parts of the solenoid valve are bad.if your standing in front of the machine look to the right in the back you will see the water line going to the valve.turn the water off,remove the black coil and set aside,then unscrew the valve with a pair of channelocks or pipe wrench.clean all the parts up and reinstall.if this doesnt do the trick you need to replace those parts.let me know.
Posted on Mar 29, 2008
I have AM14C Hobart dishwashing machine and when the rinse turns on we only get about 5 PSI, how do I adjust the pressure or what do I need to look at?
the pressure regulator turn screw clockwise to turn up pressurre.But the line strainer could be plugged do you have bad water.Is the gauge can get a gauge at home depot for cheap.0 to 60 psi should be ok.usually made by dont have to use a hobart gauge.
Apr 22, 2011 | Hobart 42 in. AM14C-154 Free-standing...
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
Can I change the 3 phase to a single phase?
Not practical. You would have to change the pump motor to single phase, you'd have to chage the heating element most likely depending on what size is in it now. Also does it require an auxiliary water heater? it's probably 3 phase also. Changing phases is not like changing voltages.
Jul 24, 2010 | Hobart AM14C-155 Dishwasher
Hobart commercial d/washer can't stop water from spraying top/bot
try not to turn off the water supply,if i where you i would get this machine checked out.What i cant understand is the machine spraying water when it has power of.adrian,,,,
Jul 14, 2010 | Hobart 29 in. AM15-1 Free-Standing...
My hobart 42 in. AM14C-154 Freestanding Dishwasher is missing the pipe part and the three face needs to be changed to a singe face.
You can get the parts at your local Hobart office. It would be very costly to change the unit to single phase. Click on "Locate an office" and type in your zip.
Jan 27, 2010 | Hobart 42 in. AM14C-154 Free-standing...
Hobart am14 water runs through it all the time
If water is running even with the machine turned off then your solenoid valve needs to be cleaned out or rebuilt. This valve is in the back top of the machine by the gauge.
Apr 24, 2009 | Hobart 42 in. AM14C-154 Free-standing...
Hobart dishwasher am14c constant water
You have a defective inlet water fill solenoid, DO NOT TRY TO REBUILD THE OLD ONE, REPLACE THE SOLENOID. Unless you are a VERY EXPERIENCED service tech. These solenoids are always going out and are not that hard to change, but they are really complicated to rebuild. Don't be cheap, get a new solenoid.LOL...I am a service tech. and change these valves all the time...Hope this helps....GOD BLESS....Randy...
Nov 07, 2017 | Dishwashers
Programming the 00-749825 Control Board on a Hobart AM14C
That board comes with directions. if not go to hobart and have them copy you one out of a new boards box
Aug 23, 2008 | Hobart AM14-253 Free-standing Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
133 people viewed this question
Top Hobart Dishwashers Experts
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
