Question about Brother DCP 130C All-In-One InkJet Printer
Is there a way to control font size? Either from a DOS command or a windows setting page? Even to be able to switch from normal to compressed font would help.
  • 10,515 Answers
Read the below link :-
http://www.microsoft.com/windows/ie/community/columns/shrunk.mspx
The above link would solve the Purpose.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 11, 2010
  • mjt5517 May 11, 2010
    Thanks for help, but doesn't 'hold' the font size as default.
    When I quit out of Windows to run a DOS program, the print size has gone back to normal
    Cheers
    Mike
  • taran_2005
    taran_2005 May 11, 2010
    Thanks for your response!!
    Unfortunately, it Cannot be Set as Default. You need to manually Change it. The only solution would be to Copy the text into MS Office and then use that Software to Narrow Down the Text.
    The printer settings are made in such a way that it would accept the Font Size relative to the Document.
    I wish i could have a Better Solution.
    Hope i helped you.
How do I make my screen size smaller? It just became huge suddenly
You likely zoomed in with control-scroll up/down, try control-scroll to zoom back out. If only the font (not the windows) got larger, reset font view size with apple-0 (command-zero). HTH.
Feb 22, 2015 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Will lotus 123 load from a cd on windows 8
you have to create a batch file to run Lotus 1-2-3, and (so far as I can tell) you have to run the program from your root drive, because the program makes its calls TO the root drive. Here's the batch program you create in Notepad or other plain-text editor:
cd\
cd\lotus
123.exe
cd\
exit
* Delete the 'exit' if you want the window to stay open as a DOS window, after you're done with the program. Save the file with a '.bat' extension. (Note: unlike XP, you can close the window with your mouse, afterwards.)
* After creating that file, you have to right click on the file name, select 'Properties (in Win8, Vista, XP) and do some more tweaking. The Properties dialogue box SHOULD show the following tabs: General, Shortcut, Options, Font, Layout, Colors, Compatibility. Each of these needs editing.
GENERAL tab: select Normal Window or even Maximized (though it won't actually maximize). Also in Win8, click on Advanced, and 'Run as administrator'.
OPTIONS tab: select Large cursor. You can always change it, but since the program really won't run fullscreen, you'll want the cursor to be oversized, since the window will be smaller and will shrink everything in it.
FONT tab: this is what Windows uses to select the screen size, despite all the other settings (which you also still need to set). In Win7, you have three types of fonts to set. Click on the 'Bold' option, as that makes the text easier to read.
For True Type 'Consolas' font (which results in a more square window), pick a font size between 18 and 24. More than that will be bigger than your entire monitor screen, when you actually run the program (looks are deceiving, you have to test the results with trial and error).
For True Type Lucida Console font, use the same 18-24 font size range, but the screen will be much shallower and wider, so you can afford to decrease font size to 18-20. 28 is really too wide, on a widescreen monitor (1366x768 pixels). But maybe you'll like it, or your monitor will accommodate that size. Mine wouldn't.
For Raster fonts, 12 x 16 is the optimal setting. ON some (i.e., Dell Ultrasharp) monitors, Raster fonts look best. On my Toshiba 19L4200U TV monitor, the Lucida Consule setting is clearest.
LAYOUT tab: Pick a window size width no greater than 85, and height no greater than 38. Then test to see if it's too big. If yes, you'll also need to decrease font size, as well as the Layout size, here. Experiment, because you can't gauge the right mix of window and font size, just by the diagrams in the dialogue box.
COLORS tab: Lotus 1-2-3 makes hardware calls on the screen, so whatever you put in this tab, it will ignore. But other DOS programs might 'obey' the colors you set here. If you remember the old Norton Utilities days of setting Mode, etc., that's what this is.
COMPATIBILITY tab: You can't set resolution to override at 640x480. The setting is either ignored, or your monitor will freak out. For Lotus 1-2-3, in Win 8 I didn't need to turn on the 'compatibility mode'. It made no difference in the results. (You don't need it in XP, either.)
* Finally, you have to find the program itself, then right-click on the program name and edit its Properties. Here, that program is 123.exe, and it has to be in your root directory. (All the program files Lotus will use, must be there; at least one wk1 file must be in C:\123 at startup. I'm sure this can be tweaked, but I'm using the default Lotus program settings for a typical installation.)
Jan 04, 2013 | Dell Optiplex GX270
Normal size for dpi
DPI, or "font size" is variable, depending on your monitor's native resolution, The resolution you have selected for it in Windows (Desktop-->Properties[right-click]-->Display Properties-->Settings), and what program you are currently using (browsers can be "zoomed").
I would try adjusting your monitor resokution first, before changing display font size. Try this page for some help with XP: http://www.andybrain.com/qna/2008/02/09/how-to-change-the-font-size-in-windows-xp/
This page for help in Win7: http://www.sevenforums.com/tutorials/443-dpi-display-size-settings-change.html
There really is no such thing as "normal" DPI font size. Most people with decent eyes would probably use 96 as a standard.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
Font is very big
Hi jjsbeach...
You need to check two places to see about reducing the font size.
Note: > ...means to go to or next
1...Look in the right hand corner at the bottom of the page and you will see may see 100%...if you do not then click on the arrow down and a window will open allowing you to size the window from 50% to 400%.
2...Left double click "Start">Control Panel>Appearance and Themes>Display>Appearance, look down at the font size and make sure it is set to "normal"...
If you are sending an email and you want to make the font smaller,larger, or a different style then you will need to open your email and look at almost 1/4 down the page on the left hand side of the page, you are looking for a tiny pair of sissors in line with other items, in that row you can change your font/style/size.
You can adjust the size of your font/change font style, etc. all from the bottom of that window
Please take time to rate me
Aug 01, 2011 | Computers & Internet
How to change text size to be larger
This depends upon what program you are running.
If you mean the Internet, you can change the view settings on most browsers by zooming in (go to "View" in your toolbar).
If it's a Microsoft application like "Word" or "Excel", you can increase the font size or the magnification of the document - again, from the toolbar.
Mar 03, 2011 | Computers & Internet
My writing is so small i can't read any thing on my computer because of this i can't read anthing you write back so can someone call me at 901-283-0239
You can increase the size of text by pressing control + or - buttons press control button first. Also there is zoom in the tools section and also you can increase the size of text in the control panel or the web page under tools sections of most browsers. If we new the browser or what you text is small in or even if it was small every where you can change the resolution size of your Windows. Win 7 you can incease text by going to control panel click on display once there go to where it says increase your text size. Not sure what your operating system is either. So assuming it is Win 7 I hope that this assists you. John
Jan 26, 2011 | Computers & Internet
Need to increase font size without effecting pixel clarity
The first step for optimal readability is to set your PC's graphic output to the native resolution of your monitor.
The Samsung 2033SW is a little unusual in this regard since it provides a matrix of 1600 x 900 pixels, which is not very common.
If your graphics board has DVI output, I'd also make sure to use a DVI cable to connect to the monitor instead of VGA.
Windows XP and above support a font rasterization technology called "ClearType", see http://en.wikipedia.org/wiki/ClearType. This page also provides references to the ClearType tuner PowerToy for XP, which is available to Windows users at no extra charge. Windows 7 has a control panel for ClearType out-of-the-box.
If you still need to increase font size, you can increase it from the Display Control Panel, too, "Medium" font size scales to 125'%, "Large" fonts to 150% the normal size.. Changing the DPI (dots per inch) setting in the monitor control panel cannot be recommended since some software cannot cope with alterations here (dialog boxes or user interfaces with text in wrong places or sticking out of the window... yeeks.)
Feb 07, 2010 | Samsung Syncmaster 2033SW Monitor
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Print is compressed on the page. Need to stretch
Compressed print is either a font selection issue or a call for a "SI" (Shift In printer control code)
I suspect the problem can be fixed by going into the printer menu and printing out the printer settings.
Look at the default font and see if it is set to 17,1 or 15.X cpi spacing. If it is then that's the problem.
Change the font to a 10 or 12 cpi spacing (Character per inch).
If the setting is fine, then send me a "Print to File" and I can tell yoi if the software is controling the printer. My address is don.farr@verizon.net
Also, check the application you are using to generate the data file. Make sure you have the correct "Point" size selected for the font.
Don
Jan 20, 2010 | OKI Pacemark 3410 Matrix Printer
Brother DCP 130C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
