Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have a 6220 chlorinator, worked fine last year. This year it appears as though it is working, ie the left hand green light comes on, about ten minutes later the right hand green light comes on, but the tank water level doesn't drop and there is no chlorine going into the pool, though there is bubbles in the water as it flows back into the pool. Any clues as to what the problem might be.
  • 272 Answers
SOURCE: no chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Posted on Jun 01, 2009
SOURCE: I have an intex salt water chlorinator and I have
manual says to run 4 hours in temps up to 82 degrees, 5 hours up to 97 degrees and 6 hours in temps up to 108 degrees. This is for an easy set pool which is 18 in diameter and 48 inches deep.
Posted on Jun 23, 2009
  • 297 Answers
SOURCE: i have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Posted on Jul 12, 2009
  • 297 Answers
SOURCE: Low flow indicator light comes on chronically.
If you have a valid receipt you can call intex and they will send a new one out to you in 24 hours. No cost to you just fax them the info they request
PAINLESS!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jul 21, 2009
  • 297 Answers
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Posted on Aug 13, 2009
It will not charge and the green light does not come on I have it apart and no loose wiring
Car will not take charge ' Forums ' Tesla Motors
www.teslamotors.com/it_IT/.../car-will-not-take-charge
Tesla Motors
26 posts - ‎14 authors
The cable is green-light, connector plugged in, but the charge port does not lock or take charge. ... Ranger will come to you and fix it in place (if it is possible).
MacBook Pro (Not Charging) but Green Light Stil... ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jan 13, 2013 - MacBook Pro (Not Charging) but Green Light Still On .... It was just working fine yesterday though, the battery lasted like 5 hours, how does it just die like that? ... A car may be designed to last ten years, but if you drive 60,000 ...
Dec 25, 2015 | Cars & Trucks
My salt water system seems to be working but no green light. I pushed the reset button but still no light. Also I want to boost as it has rained. I would appreciate it if u know what is going on....
Here's how I check if my system is generating chlorine... Light or no light...
I take a sample right out of the chlorination/ pump exit fitting in my pool and test for chlorine level. It should be out of the chart reading... If using strips, should be the highest reading or darker... If using OTO drops (Orthotolidine). The color should be dark yellow or 5.0 or higher... If you know the chlorinator is working and generating chlorine, the green LED light may be burnt??? You would need to very handy at electronics to be able to replace the LED light inside.. If you don't want to hassle with the light and testing.. The 8110 model is on sale at Wal-Mart (on line only) for $149.00 with a $50.00 gift card.. Just like paying $99.00.. Great deal.. I'm buying one for spare.. Cheaper than 1 year worth of chlorine!!! As for the boost cycle.. If your level is low and not too hot where you live, may not need to boost??? Good luck and hope I helped???
Aug 14, 2011 | Intex Automatic Salt Water System for ...
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
All lights are on and everything appears fine but the unit does not appear to be producing chlorine. Have had unit on for two weeks but testing shows no chlorine . Salt level is fine and unit is only in...
I am not an expert on the Duoclear but I have had mine for 5 years and have not had any problems. This unit and all salt water systems will not generate chlorine when the water temperature is below 65 degrees f. I am not saying that this is why yours is not generating chlorine, just commenting in case you were unaware.
May 25, 2010 | Zodiac Duo Clear System Chlorine...
Green light will not come on chemicals are fine
You may have a chlorinator cell that needs cleaning. I usually use muriatic acid diluted 4 to1. Find something you can submerge the cell in and be careful of the acid. If this doesn't help then there is probably something wrong with the cell or the control box.
Happy pool management.
Aug 07, 2009 | Intex Automatic Salt Water System for ...
No green light....no chlorine generation
make sure you have at least 3000ppm of salt content'
set your timer for generation - the green chlorine light will not come on for at least 5 minutes sometimes up to ten
make sure you run the generator for at least 4-6 hours the first time
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Intex system not giving chlorine, no errors but no green light
I found I had the same problem. I would set the hours, it would count them down but the green light would NOT come on indicating it was producing chlorine, yet the sleep light would light up after the count down so I knew the light was working. I checked my salt, made adjustments, had to do shock treatments to keep it clean. Today I  found out that the manual is incorrect in how it says to set it. After you set the hours, instead of pushing both the arrows at the same time until it beeps, push the down button until it beeps, and then the up button until it beeps. For 2 months I have fussed with this system, and finally the green light came on and my test strips indicate it is producing chlorine. Yeah! To bad intex does not seem to mention this on their web site.
Good Luck
Mobile caught in rain storm!
It seems that there are some water traces inside. Use your hair dryer without heat on it for a few minutes and try again. repeat the process a few times. Keep spending ten pounds as the last resort. And in future remember the hair dryer whenever you bathe your mobile. Also remove the battery soonest possible.
Jul 03, 2009 | Nokia 6220 classic Smartphone
03 vectra c 2.2 sri
Ha Ha, you fell for the old Vauxhall / GM dead bulb trick didn't you !!!
You're thinking "hold on though the 'Bulb off indicator' on the dash isn't lit but the foglight bulb doesn't come on ???
There is something posted elsewhere on the net about this problem as I had this problem too and I didn't believe either?
The thing is whilst all of the necessary hardware is there for the rear foglight on that side ie: lampholder, bulb, wiring etc! it isn't actually connected to the harness. Therefore you will never get the light to work because there is no power going to that particular light.
Vauxhall say that the bulb may be used as a spare for the other side though ??? handy that eh ?
Aug 04, 2008 | Pioneer KEH-P1010 Cassette Player
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
78 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
