Question about Maisto Ford Svt F150 Lightning P/U Truck
1989 ford f150 how do i disconnect fuel line
    Problem Solver:
  • 6 Answers
You need a special to release the spring inside of the line. It's a fairly cheap tool that's made of plastic and slides over the line. You push the fuel lines together insert the tool while pulling back out.
Posted on May 24, 2010
1989 ford f150 starts but wont stay running
When is the last time you replaced the fuel filter? They are recommended about annually or every two years. Could be a fuel clog. Are the fuel lines leaking anywhere underneath the car?
Dec 23, 2011 | 1989 Ford F 150
My 1989 Ford F150 will not pump fuel from the rear tank Please advise problem
Most likely it is the cross over..It could also be a fuse.Check to make sure you have power going to the cross over It is between the two tanks with fuel lines going to it and a wire.Hope this helps good luck
Jun 11, 2011 | 1989 Ford F 150
89 ford f150 in-line 6 cylinder. i have replaced a few injectors both fuel pumps and filter. idles like a dream. when i hit the gas it studders but doesn't die. need more info ask. any ideas?
This is for a 1989 Ford F150 In-Line 6-Cylinder (4.9L) wrongly posted by the Asker under a 1986 Ford Mustang....
Fuel Injector Pressure Regulator. Look it up on line at any of the reputable auto parts websites to get an idea what it looks like.
There should be a Rubber Vacuum Line coming from this (the Regulator is located on the Fuel Line prior to the Fuel Injectors) to the Intake. Take this Line OFF. If there is gas in that line = The Fuel Injector Pressure Regulator diaphram is broken and the Fuel is being dumped into the Intake and NOT being advanced onto the Fuel Injectors; and the Regulator must be replaced.
Let me know if this helped.
Apr 01, 2010 | 1986 Ford Mustang
Ford f150 yr 2000 how to remove the fuel filter
Filter
Special Tool(s) st1463a.gif Fuel Line Disconnect Tool
310-052 (T93T-9550-AH)
Removal
  1. Use the Fuel Line Disconnect Tool to disconnect the fuel lines from the fuel filter;
Installation
  1. NOTE: When installing fuel lines to the fuel filter, push the lines onto the ports until a definite "click" is heard, then pull on the fittings to ensure they are engaged.
    Install the fuel filter.
  1. Connect the fuel lines.
Feb 28, 2010 | 2000 Ford F150 Flareside SuperCab
How to change a fuel pump in 2000 f150
1) Drain the fuel tank
2) Remove the fuel tank
Special fuel line disconnect tools are required to disconnect the lines.
3) The fuel pump is an integral part of the fuel sending unit and is serviced as an assembly.
4) Install in reverse order
Feb 24, 2010 | 2000 Ford F150 Flareside SuperCab
Remove fuel pump 85 f150
Externally Mounted Fuel Pump
High pressure EFI fuel pump
  1. Disconnect the negative battery cable.
  2. Depressurize the fuel system.
  3. Raise and support the rear of the vehicle on jackstands.
  4. Disconnect the inlet and outlet fuel lines.
  5. Remove the pump from the mounting bracket.
  6. Install in reverse order, make sure the pump is indexed correctly in the mounting bracket Insulator
Nov 13, 2009 | 1985 Ford F150
How do i change a fuel filter on a 2001 f150
The clamps are just a secondary lock, special tools are needed to unlock the fuel lines.
Nov 05, 2009 | 2001 Ford F150 Styleside SuperCrew
I have a 89 ford f150 4wd what is the name of the canister that sits behind the fuel pump on the frame parts stores can't find it
that is the fuel filter cannister, the ford dealer will have the filter, but not all have the filter installed.
Sep 18, 2009 | 1989 Ford F 150
Remove fuel lines from the fuel filter on a 93 f150 ford truck
There is a special tool used to disconnect the lines from the fuel filter. You should be able to get them at any local automotive shop, i.e., Pepboys, Autozone, Chief Auto. It should be relatively cheap to buy this tool.
Sep 27, 2008 | 1993 Ford Club Extended
Maisto Ford Svt F150 Lightning P/U Truck Logo
157 people viewed this question
Top Maisto Toys Experts
ray gallant
Mai Lor
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
