Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Just opened pool for 3rd year, I cleaned the filter added new powder, motor very noisy and must bump the filter every 30 minutes
  • 106 Answers
Filter needs to be disassembled, cleaned, acid washed and reassembled. Motor probably needs to have new bearings installed or be replaced
Posted on May 11, 2010
I have a 2 speed pump. Normal filter pressure 20. backwash when 30. filter pressure less than 10. pump very noisy. not enough flow for heater ti turn on. not enough water flow to help auxilary...
IF THE PUMP IS NOISY , SCREAMING . GET IT FIXED NOW ! THATS A 2 SPEED AND YOU DO NOT WANT TO KNOW THE PRICE OF A NEW ONE. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY, CHANCES ARE YOU WILL NEED THE BEARINGS IN THE MOTOR REPLACED, AND SHE WILL BE GOOD AS NEW.. ASK HIM HOW TO TAKE BETTER CARE OF YOUR PUMP, AND FILTER .. HE CAN SAVE YOU THOUSANDS $ OVER THE YEARS ! IT'S WHAT I DO..GOOD LUCK AN VOTE IF I WAS OF HELP.. YOU KNOW I DO THIS 4 FREE RIGHT ? .
Sep 10, 2011 | Pool & Spa
Have a pentair ccp320 filter.brand new last year.pool water has been cloudy for two weeks.water is balancedexcept akalinity is high at 200.suspect filter problems.water was clear for a month.cleaned...
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
Jun 28, 2011 | Pentair Clean & Clear Plus Ccp320 Pool...
The filter was backwashed the filter and tnen set on filter adding the powder and the powed er started coming out the return line? what is wrong/ I would like to know how do you clean the filter it was...
You probably have holes in your grids and will need to replace them. You can find a manual at http://www.pentairpool.com/index.htm
Just follow the menu's to get to filters and manual's be sure to have your model number.
Sep 05, 2010 | Pentair Fns Plus 48 sqft De Pool Filter...
Cloudy water
need to clean fingers with TSP degreaser then muriatic acid then they will take on the DE
Sep 14, 2017 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
My new ec50 is clogging frequently. Is at 18 psi
lower the better (psi) this means the water is flowing fast through the filter, high pressures means it's time to clean filter again. keep cleaning until the pool is squeaky clean, then you can go back to cleaning once a week
Jay the pool pump motor repair guy Longwood Florida
Jun 15, 2017 | Hayward EC50 SYSTEM W/ 1 HP MATRIX PUMP...
My filter has to be bumbed every 5 mins or so
The first thing to do is clean the filter.. Open the valve on the bottom of the filter, bump the handle a few times and then turn pump on and run it for a few seconds(15-20) Repeat this until water runs clear. Close valve and then add DE, If that does't solve the problem. filter needs to be disassembled, cleaned and acid washed. If that is the case, write back and we will give detailed instructions on how to do this.
Jun 01, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
A pool store installed the wrong size filter for my inground pool. It wasn't until I called for the annual filter clean that the tech told me I had the wrong size filter for my pool installed. They...
You just need to break the filter down and hand clean the grids inside the filter. This is something you should do once a year. As far as the water getting green you will need to get chloriene in the water. This is chemestry and the filter is just for filtering. One will effect the other but they are two different things. Green water will cause the problems in the filter you describe, So killing the alge should be done first.
May 13, 2010 | Hayward SAND FILTER, PRO SERIES
Proline 1.5 hp pump gets hot and trips breaker.
motor is locked up in the motor are two bearings they will rust if they are set up for a while.you can take the back off the motor and where the shaft goes thru the houseing take a pair of needle nose plires and try to free it up.
Jul 03, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward eC-40 pump losing pressure very fast
A better way to clean the filter tubes in the EC40 is to remove the filter tube assembly and soak it in a 5 gallon paint pail that is filled with a solution of water and a 20% muriatic acid, available at hardware and home center stores. Be very careful handling the muriatic acid. Don't splash it around.
Mix it in a 1-to-1 ratio with water and soak the assembly for at least 8 hours. Keep the soaking pail out of the reach of kids and animals.
Remove the assembly, properly dispose of the acid mix and refill the pail with clean water. Soak again for 3 to 4 hours, then reassemble your filter.
Some pool guys say it isn't necessary to soak the tubes in clean water because the muriatic acid will not harm the pool water and will reduce the pH if it's too high. I've always soaked them to be safe.
This is a link to the Hayward manual that describes the process:
www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jun 25, 2009 | Hayward EC-40 DE Pool Filter with pump
Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
Dec 16, 2007 | Broan-NuTone Intermediate Whispaire ...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
138 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
