Question about Dometic Rooftop RV Air Conditioner
Dead in the water
This happened in 2000 under warranty & the tech replaced the power board. just wonder if it is probablythe same problem ?
  • Dometic Master
  • 6,674 Answers
Have you checked for fuses in/at, thermostat ? What type of RV is this in? Power board should need to be replaced again, if at all, my guess is it's something else. Do you hear any "clicking" form unit when you move thermostat to other settings? Is nothing working at all, fan, furnace etc?
Posted on May 11, 2010
GE oven is completely unresponsive but I have power to the plug that goes to the board. I see no obvious signs of damage, no burnt anything, not even a smell of burnt stuff.
Hi, Did you check the fuses on the stove. If it was built before and after model year 2000 there still should be fuses. If your stove is still under warrenty you may be able to get it fixxed for free. Good luck.
Feb 21, 2015 | GE Microwave Ovens
I have an element TV with a MLT070A power supply board. I'm not an electrical guy, but a technician came out and showed me the bulged caps and said that was what's wrong with the TV. He said he...
power supply board is dead, if you know basic electronics' and soldering you can handle it ? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.
Good luck in solving the problem.....
May 17, 2011 | Televison & Video
My dell laptop dont turn on
Is there a green light on your power supply that plugs in the wall? If not, the power supply is dead or there's a problem on the motherboard.
To troubleshoot, unplug the laptop from the power supply, unplug the power supply from the wall. Now, plug the power supply into the wall, you should see a green or blue light. If there's a plastic spot for the light but no light is coming on, replace the power supply - better to try a known working on before spending the money on a new replacement first.
If there is a light, plug it into the laptop. If the light goes out when you plug it in, there could be a motherboard problem and the board needs to be replaced or the power jack is damaged and you need a professional to replace it.
If the light is on the whole time, but laptop does not turn on, this could also mean that the board is still bad.
Regardless if it doesn't power up with a good power supply it is usually a motherboard problem and the board needs to be replaced.
Check with dell to see if its under warranty and they will send the parts needed and a tech to replace if it is. You can also ask about purchasing a warranty so your money is better spent to keep your laptop alive and put it towards something useful for the lngevity of the system instead of just paying for the part and a tech.
Feb 11, 2011 | Dell Studio 1737 Laptop
Hello my name is Amy & I have a 50 inch toshiba dlp (56hm66). I have no lights on or power. It's completely dead!!! I read the manual & followed everything about the lamp, how to restart, made...
Tv have no power at all?U already check the source?Yes,most likely the tv DM power supply board is dead or could be anythings on the highvoltage deflection circuitries on the tv.Check the DM power supply board like for dying or dead capacitors and circuit fuse breaker.Have no skills to do this call and get an estamate by tv Tech. to get it fix.
Jan 13, 2011 | Toshiba 50HM66 52" Television
Dead
Hello George, hi it seem your TV is on standby mode, this happens when the power supply board detects a short, overload or any part on both main and power supply board gone bad. This needs to be checked properly by a highly skilled tech people. The problem could be the main board or the power supply board. we usually check first the main board, for any bad parts, like loose screws/wiring, bulging capacitors, overheating ICs, or water marks. If a OK, we then check the power supply board, well usually this is the culprit, bulging capacitors, or overheating regulator. or you could replace the entire power supply board. check for its availability online or on your dealer, ask also for service if the charge is reasonable.
Apr 30, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sylvania 6842pe blew fuse, replaced fuse, and nothing,no lights, noise, nada. replaced power supply board with the chord attattchment and still no power, no lights, and no noise. Was wondering could it be...
Yes,replaced all the boards that related to the power supply.Useally completely dead,it effect all the ICS in the boards,never able to tell which boards.U are not a tv tech.don't do this everyday's will not have skills or any idea which board is dead.
Apr 06, 2010 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Dead. Only lights up where plugged into power cable & LED lights
Open up the case and make sure that all the PC boards are properly seated in their slots.
Check all the ;power connectors and board connectors. One of them may have come loose during transport.
Leave the case open and turn on the power to see if the fans (case and CPU) are spinning.
Let me know if this fixes the problem or if we have to further research the motherboard. Thanks.
Jul 31, 2009 | HP Pavilion dv9000t Notebook
PLASMA T.V.
ten flashes from the light is a problem that needs to be issolated by a tech the 1st board to check is the PA board,and all the boards require authorization from panasonic to replace. that is why a tech must do the repair. if the unit is under warranty they must honor the warranty. extended warranty must honor the agreement you signed or purchased. there are a total of 6 boards that can cause the 10 flashes and can be costly to repair that is why I say when ever buying these types of sets get the extended warranty. these sets are no the sets of old they are not componet level repaired but board level repaired.
Dec 26, 2007 | Panasonic TH-42PX60U Television
KODAK DX6340 won't power up
IF you still have warranty - then back to the store or Kodak it goes. If it is out of warranty - check Kodak site for tech help- they may offer a swap out for a low price.
May 13, 2007 | Kodak EasyShare DX6340 Zoom Digital Camera
Dometic Rooftop RV Air Conditioner Logo
55 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
