Question about Kenmore 54603 / 54606 Side by Side Refrigerator
My compressor has been running all day and is making a buzzing/grating sound and the temperature in both the freezer and the refrigerator appear to be warming.
  • dcash27 May 11, 2010
    my compressor runs but it has been running none stop all day and is making a weird buzzing/grating sound. Also, every once in a while the compressor will start to make a knocking sound and then go back to buzzing. The temp in the freezer and frig is getting warmer. the door seals are fine and I have already clean the condenser coils.
  • 10,515 Answers
It is either a bad compressor or start relay you yourself can only really tell by replacing the start relay.The part can be found at www.repairclinic.com however being an electrical part it is not returnable if this is not the problem if it is not the problem the compressor would need replacement ( not a job that a homeowner can do ) if the fridge is under 5 years old the compressor should be covered under a 5 year manufacturers warranty.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 11, 2010
  • taran_2005
    taran_2005 May 11, 2010
    Thanks for your response!!
    Yes, i am aware of the problems you mention. In my View , it is Faulty Compressor Relay.The ' Not Cooling Problem ' is due to the Compressor Relay.
    If Relay is Fine, then Compressor is at Fault and needs replacement.
    Buzzing and No Cooing issue's are really Common with this Model.
    Inspect the Relay and you would be able to Find the Culprit.
    http://www.ehow.com/how_4504012_test-ref...
    Hope i helped you.
  • taran_2005
    taran_2005 May 12, 2010
    I am Sorry, but i was unable to see any of your Comments??
    If you want any Further help, let me know and i would be glad to Assist.
    Hope i helped you.
  • 6,784 Answers
Hi.I would first recommend to clean the condenser coils, asap. I will post a complete step by step procedure that will help you through the cleansing process for your condenser coils.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.Now, if the cleaning of the condenser coils do not improve the functions of your unit, move on to the next area of concern.
Another area of concern will be the door seals. This is a easy way for the cold air to escape from your unit as well. this will cause the temperature to rise, and also cause the compressor to run, continuously. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seals. Replace the seal if the test was unsuccessful.
Finally, if both the door seals and condenser coils are optimal, this will lead to a failed compressor start relay. It may be stuck in the on position. Use the procedure below to inspect the relay and compressor, properly.
I would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main PCB.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each model). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proximity of the relay. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before beginning. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multimeter displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multimeter should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
SIDE NOTE:
Be sure to inspect for proper air flow from the evaporator fan, through the damper assembly. If there is no airflow, while the compressor is running, this will lead to a failed evaporator fan motor. Start with the condensoer cleaning process.
  • 6 more comments
    the compressor is running but it's making a strange buzzing sound. Not sure if you got that. Also, every once in a while it'll will start making a strange knocking and clunking sound and then go back to a buzzing sound.
    I'm not sure if you caught the fact the compressor motor is running but it's making a BUZZING sound, which is unusual. Also, every once in a while the motor will start making a knocking and clunking sound and then go back to buzzing.
    are you getting my replies?
  • Michael Masters
    Michael Masters May 11, 2010
    Yes, please allow for proper response time, due to fluctuations within the systems performance. I totally understand your issues here. I have seen this many times. I understand that it is running, but that noise is a very strong indication of compressor seal failure, within the compressor assembly. Normally, this will occur if the compressor unit has overheated itself, due to a dirty set of condenser coils, which in return, will induce very abnormal run-times for the compressor motor. Use my compressor testing procedure to confirm.
    • NOTE_ make sure the compressor has not become loose or detached form the platform. If the compressor is detached, due to corroded mounting devices, this will cause noise, as well. i suspect compressor failure, due to failed seals in the compressor motor assembly.
  • Michael Masters
    Patient's is a virtue....
  • Michael Masters
    Good luck:)
  • dcash27 May 12, 2010
    just called Sears. Yes, patience is a virtue but when I responded to you, there was no indication what so ever that my reply went through. That's why i sent it like three times. Fixya needs to Fix this!
  • Michael Masters
    Michael Masters May 12, 2010
    Its not an issue with my response time at all. I responded to you, immediately. There is a slight delay when messages are sent to an from the corresponding parties. During peak hours, this response time will be increased. That's why patients is needed when waiting for a response from an expert.
    I am confident in my solution that i sent to your page. Its not an issue at all.
    Have great day or night:)
Amana 25. The lights are on, but freezer has died. I hear a buzzing every 5 minutes. Is this repairable?
Sound could be relay on the compressor buzzing pull back cover you'll see compressor and condenser fan when fan is running compressor should be running you can fell it vibrate when running if its not try replacing over load protector and relay. If that doesn't fix it compressor is probably bad and cost too much to replace
Jun 07, 2015 | Refrigerators
Freezer compartment is thawing
Sounds like the compressor seized. The buzzing you hear is the compressor trying to kick on.
I noticed that happens a lot with air conditioners if power is interrupted when the compressor is running.
Did you try unplugging it for 20-30 minutes?
Sometimes letting it sit unpowered relieves the pressure that was built up in the compressor, making it easier for it to start.
Jan 10, 2008 | Maytag MFD2560HES Bottom Freezer French...
My JMB fridge freezer is not working
usually if the buzzing sound is eminating from the compressor it is a defective compressor and theres no fix except to replace it
Apr 26, 2012 | Refrigerators
I have a side by side fridge/freezer. the other day the freezer quit then a few days later the fridge quit. the compressor is still running. no temperature. could it be the timer or both stats defective,...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | KitchenAid Refrigerators
The refrigerator is still functioning, but even adjusting the temperature control does not make it cooler ... we have clean the coils underneath, but it has not appeared to help . There are not odd sounds...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | Refrigerators
Freezer and fridge not cold
Sounds like you have a stuck compressor. The buzz is the compressor trying to run but cannot.
A refrigeration mechanic with an hermetic compressor tester can reverse operate the compressor to get it unstuck
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer keeps buzzing
don't worry! its the sound of compressor vibration and it is normal........if the sound is more than turn round the refrigerator and tight the nuts of the compressor stand......................have a nice day:-)
May 14, 2009 | Samsung RB2155SH Bottom Freezer...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Kenmore 54603 / 54606 Side by Side Refrigerator Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
