My GP4104 runs down from charge in less than 15 minutes. What should I do?
    Top Expert:
  • Computers & ... Master
  • 77,194 Answers
U are going to need to replace the battery in whatever this device is.
Posted on May 11, 2010
Left my lights on for a few days on my toyota corolla 2006. It wouldn't start obviously except after jumping. Now works, but even 1 15 minute drive on the highway did not charge it completely. Also, n
It is possible that your battery is not charging at all, or the jump start has damaged the voltage regulator. Your battery should have been charged sufficiently after the 15 minute run, so there is another problem.
Check the voltage with a meter - I think Radio Shack should give me a bonus for recommending them so often, but you can get a relatively cheap (less than $5.00) meter from them that will give you an accurate reading.
Connect the meter across the battery terminals and check the voltage. It should be over 12v. With the engine running at just over idle the meter should slowly move to 13.8 or possibly as high as 14.2 volts. More than this, replace the regulator. Less than this, replace the regulator.
The regulator is mounted inside the alternator. It is usually possible to remove and replace the regulator without removing the alternator. The regulator is a fully replaceable unit complete with the slip ring brush gear, and is held in place by two small screws. The new unit should have a wire through the brushes holding them in place,
If it doesn't have one you will find the brushes are almost impossible to put back, so the trick is to locate the small hole in the front brush holder, then gently push the brusher into their respective holders - the brushes have tiny holes in them corresponding with the hole in the front brush holder. Now keep the brushes in place with a thin wire - a paper clip works fine. After replacing the unit, screw it down and then remove the paper clip,
Reconnect the little electric wire, and your problem should be fixed.
Oct 06, 2014 | 2006 Toyota Corolla LE
Tip
Cordless power tools
To maximize your battery life let them cool down 15 minutes before you put them on the charger.Also let them cool down after charging before use for 15 minutes.Store your batteries with a full charge and condition them every month by using them a little bit and return them to the charger for a full charge.
on Oct 20, 2010 | Drills
My 1995 3litre picup starts then runs for 15 minutes and wont start back up untill i charge the battery up again. i have a new batterey and altermator.
It almost sounds like your "new" alternator is bad. Check all connections and if you have access to a voltmeter - attach to your battery and voltage should be 13.1v-14.8v anything less your Alternator is bad.
Mar 29, 2011 | 1995 Nissan Pickup
PC Charge Pro 5.9.1 shuts down after 15 minutes of inactivity. Is there a fix?
I am having the same issue. Has anybody found a solution for this. I can not have it shutting down every 15 minutes,
Jul 01, 2010 | Go Software Inc. PCCharge Pro...
Battery runs out in less than 60 min, used to go for hours.
Hi. With batteries it is very important to recharge them after each use, overnight. I have seen batteries last 7 years in a mobility scooter, because the batteries were charged properly. Batteries store electrical energy by means of a cemical reaction, and if left in a discharged condition for too long, damage is done to the internal plates of the battery.
Batteries are designed to do so many charge cycles.
If a battery is run down to 75% or more, you will not get many cycles out of it. If you only run it down by 25%, you will get 100's of charge cycles out of it.
I would say that you will need to purchase new batteries for it.
When changing the batteries, change one completely first, and then the other. This way you will be less likely to mix up the wires.
Red is positive, and black is negative.
Good luck. Neil.
May 30, 2010 | Quickie Wheelchairs Quickie Wheelchair 18"...
Doesn't hold a charge
Again as above your battery may need replacing see if its still under warrenty
May 22, 2010 | SanDisk Sansa Clip MP3 Player
The battery keeps going dead after only a few days.
check the battery voltage with the car running, you should see 13.5 to16 volts dc if the alternator is working. Make sure you are not doing short runs all of the time when starting a car it take approximately 15 minutes to bring the battery to full charge so if your trips are under 15 minutes all of the time the battery will run down. if everything else looks ok it is possible you have a bad battery or something is left on in the car
Nov 05, 2009 | 2004 Volkswagen Touareg
Rear glass goes up or down, but only after truck drives or runs for about 15 minutes. shut truck off and wont work till drive or run for about 15 minutes. 87 4 runner
chk your battery voltage before you drive and after. The window motor is probabaly drawing more current for some reason. and needs the voltage available after a short charge. May be too much resistance in window guides. Lubricacate everything you can with silicone spray includeinf the side guides/tracks. Good Luck, Ned
Oct 04, 2009 | Toyota 4Runner Cars & Trucks
Scooba
Sorry to say, but you have a bad battery. If it's still under warranty, call them and they should replace it. If not, you'll need to buy a new one.
Apr 05, 2008 | iRobot 5800 Scooba Vacuum
Motorola H700 charge issues
The rechargeable battery may have reached it's limit of recharges. You can try leaving it on until you no longer see life (any light) coming from the H700. You want to drain it completely. Than charge it, (take note of how long it takes to reach full). If it dies like before in 15 minutes than the H700 is dead. You can take it to a Motorola store & might be able to exchange it for less than you first bought it. Or you can go here (Click the link) for a new one. http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=Motorola+H700&image12.x=13&image12.y=15
Luck!
Mike
Apr 01, 2008 | Motorola Mobility H700 Wireless Headset
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
