Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
I dont know what wires go with what for my memory harness
Color code
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
i dont know what wires go with what for my memory  - modified-life-logo.gif.com gives out free diagrams for stereo installs check it out helped me out now im spreading the word..
Posted on May 12, 2010
4 Suggested Answers
thesoundman
  • 41 Answers
SOURCE: WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
motor1258
  • 6674 Answers
SOURCE: I removed my stereo from my 2005 Chevrolet Tahoe.
Check out this link. Should have necessary info for you.
http://www.the12volt.com/
Posted on Feb 25, 2011
Color codes for stereo
They make kits just for this. Just plugs into the existing harness and then you run you wires to the wires from that harness, some may even have matching plugs that go directly to the Head units wire harness plug. I did My Mustang by cutting into the wire Harness and simply used a multimeter to check for battery, memory 12 volts and running light or dash board Illumination wires then you can test the wires coming out from the stock radio to see which are right, left , front, rear, antenna out, etc..
I just labeled them with magic marker on some masking tape with what they were before I cut off the harness permanently.
Jan 23, 2014 | 1999 Ford Contour
NEED WIRING DIAGRAM
If you are referring to installation and have the aftermarket wiring harness, The wires should be color coded. RED, YELLOW, & BLACK are power, ignition and ground. These should correspond to matching wires on the back of the head unit (CD player). Match the colored wires from the back of the unit to the same colored wires on the aftermarket harness and then connect them using wire connectors/wire nuts. Once you have them into the correct order the aftermarket harness should connect into the harness in your vehicle. I hope this answers your question =)
Nov 05, 2013 | JVC AM FM CD DET FACE CAR STEREO
I have a used kenwood modle kdc-2165. all the wires but no color codes. and i am putting it in a 1988 ford f150 custom, also i have the wire harness but no color codes. and i have a yahoo email...
If you are installing a radio, I recommend you purchase a wiring harness specific to the vehicle you are installing into. You can find them at places like www.crutchfield.com . If you are just looking for a wiring diagram to hardwire the radio, try www.mobileinformationlabs.com
Aug 29, 2011 | Car Audio & Video
I want to install in my car a panasonic car stereo AM/FM/CD player CQ-EN9680TA, i dont know the wiring code of the terminal (power and speakers connections), can you help me pls? thank you
Hello marlomeneses,
Wiring color codes are different for different makes and models. Go here and select your vehicle for the color code: www.modifiedlife.com
The best way is to purchase a vehicle specific wiring harness that plugs directly into your car wiring. Splice the wires from the harness that came with your new Panasonic to the vehicle specific harness and plug them in.
Here's an example of such a harness made by Scosche. This one fits 2002 and newer Chrysler/Jeep vehicles. There's a harness for most all vehicles. Local car audio shops, Best Buy, and even WalMart sell such harnesses.
http://www.sonicelectronix.com/item_1669_Scosche+CR02B+-+CR02.html
Hope this helps.
Oct 06, 2009 | Panasonic Car Audio & Video
Cant hook up car stereo
this is an easy one... go online and google search -color codes for whatever your car is stereo wires
May 05, 2009 | Car Audio & Video
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Dont know how to insall it !!!
Purchase the aftermarket wire harness at from a local installation shop. WIres will match color for color to this harness then mate to the factory connector. This could save hours attempting to figure out the factory wire harness.
Nov 11, 2008 | Pioneer DEH-2800MP CD Player
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Jan 12, 2008 | Car Audio & Video
INSTALLING A CLARION MODEL DRX6375 CAR STEREO INTO MY HONDA ACCORD 1995
If you go to your local stereo shop (or even Wal-Mart..) you can get the harness that plugs directly into your cars wiring for about $5-10. It will have the EXACT same wire colors as the harness that came with the Clarion. Just match them up, plug it in and you're good to go!
Nov 09, 2007 | Clarion DRX6375
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
143 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
