Question about Archos 504 500870 Digital Media Player
Arch 504 i change hard drive
Hi i change hard drive on my arch 504 but when i turn it on it sys usb format how can i get it work
  • 28 Answers
You can´t swap the internal hard drive if your current firmware is superior to v1.4.0, because system locks it during bootloading (system reads hard drive ID).
Posted on Apr 13, 2011
My verbatim model # 47562 is not working on Window 7.It was being used on Mac and was formatted for Mac. How do i reformat it for windows 7
Need to plug it in sys you wish to use,go to my computer choose drive and in propertys choose format option.Good luck!
Jan 09, 2011 | Verbatim (47562) 250 GB USB 2.0 Hard Drive
ARCHOS 504
Did you try flashing the firmware on the unit?
Mar 27, 2008 | Archos 504 500870 Digital Media Player
How do i format a san disk cruzer 2 gb ?
insert drive into usb then when it appears in sys as removable drive right-click it and select format, then FAT32 system, other options on default
Sep 23, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pen drive not working
format the drive using linux operating system .. and then format it in windows operating sys...
done...
Sep 20, 2009 | Electronics - Others
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Kingston dti/1gb
Have you tried finding the drivers for the USB Flash Drive?
Sometimes XP may need a compatibility drivers.
Mar 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Windows won't start
hi i as you said you have no cdrom you are using an external cdrom this may be your down fall but i shell try my best for you ok .
first start the laptop up press f2 or del to go into *********** board settings when you have done that move your arrows to the right finding your boot option go into that and remove your hard drive from that this will make your sys search for the usb or cdrom to load from then you must save this on leaving the motherboard when you leave it will say save y do that then it will restart and find your cdrom make sure that you have the windows disk in the cdrom before you start ok follow the on screen insturctions telling you to format the hard drive this will wipe the hard drive ready for installing the new windows program on it ok
the reason when you loaded the windows on the other pc and put it in your laptop is the motherboard is not the main op sys for the hard drive hope this work for you if not get back in touch and we shell try another way ok thanks all the best
May 22, 2008 | Compaq iPAQ Legacy-Light PC Desktop
Archos 504
try resetting it via the button under the battery cover next to the hard drive, and if not, connect it to your pc, and format it as quick as poss.
Dec 09, 2007 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pc
c. connect 504 to pc and wait until pc recognise it
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Kingston DataTraveler2GB
Hi, I couldn't get any software utility or firmware updater/repair from the Kingston site, however, I have tried the HP Drive Key Boot Utility and it works even for Kingston and JetFlash. The bad side is it completely erases the contents of the USB drive. Should you want to venture and try it, it is available for download at http://h18000.www1.hp.com/support/files/serveroptions/us/download/23839.html file name is cp006049.exe Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 31, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Archos 504 500870 Digital Media Player Logo
122 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
