Question about Siemens 24 in. SL84A305UC Built-in Dishwasher
Siemens dishwasher pump runs while door open wont turn on!
Siemens sl84a305uc dishwasher problem...the pump runs while the door is running (which it never did before), there are no lights on top to show if its on or off. Cancel/drain does not work, the only thing it does is turn the pump on and off if you press the on/off button! Ive disconnected power in hopes of resetting the machine, with no luck HELP!
    New Friend:
    Problem Solver:
  • 6 Answers
I have same problem no water in base float not activated and no blockage in pump
Posted on Feb 28, 2013
  • Siemens Expert
  • 414 Answers
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety and give the scenario you have described, so check valve, hoses etc for leaks. You will have to manual clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large tower and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch. https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Posted on Jul 12, 2010
Siemens dishwasher- start button is flashing but will not start. some water in bottom of dishwasher.
Did you try turning off the circuit breaker to it, waiting about 15 minutes and turning it back on?
If that doesn't do it, I would start by checking your drain pump.
Oct 24, 2014 | Siemens 24 in. SL84A305UC Built-in...
Wont drain after it runs. Has standing water in it
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 18, 2011 | Siemens 24 in. SL84A305UC Built-in...
Dishwasher wont drain
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Siemens 24 in. SL84A305UC Built-in...
Siemens lady dishwasher is getting stuck on
I removed the dishwasher and put fill hose on mains pressure. (30 to 45psi or 2 to 3 bar). Working ok now. May be issue with water pressure switch ?
Mar 23, 2010 | Siemens 24 in. SL84A305UC Built-in...
Where is the model number located
normally it is on the inner panel frame of the machine which is around the door right or left side. when open the door check that location you will see it. or you can go to thermador .com they own bosch and they can get all of the parts that you need.
Mar 03, 2010 | Siemens 24 in. SL84A305UC Built-in...
Control Panel
See:
http://www.siemens-home.com/pdf/sl84a30xuc_manual.pdf
There is a pic with the buttons in there.
Aug 13, 2008 | Siemens 24 in. SL84A305UC Built-in...
Dishwasher has odor
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.
Please rate this solution.
Aug 03, 2008 | Siemens 24 in. SL84A305UC Built-in...
Siemens 24 in. SL84A305UC Built-in Dishwasher Logo
1,311 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
