Question about NetGear WGR614 Wireless Router
Need to get router in PPPOE mode - NetGear WGR614 Wireless Router
Pppoe bridge modem router
More info, you have a modem/router and another router? and what is "both" independently? and "while they are both connected" both what? If you just have one box the modem router, disable bridge mode or you just have a modem then with no routing.
Aug 01, 2017 | Linksys WRT160N Wireless Router
Canont connect to the internet using my router
Good Day,
First thing to check on way you can't connect to the internet with your Router.
1) make sure that the Ethernet cable from the Modem is connected to the internet port or to the WAN port at the back of the Router.
2) check if the Router is the using using the PPPoE settings. if not make sure that your Modem is switch to bridge mode so that you can put in your PPPoE settings in the Router's GUI. or if your ISP don't want the PPPoE to be put in in your Router GUI then you have to bridge your Router.
3) make sure that your firewall settings is set to minimal so that it will not block your Router's program.
Good luck.
May 24, 2011 | Computers & Internet
I cant get the internet to work through the router. then i also cant get my xbox to work either
This really depends on how your Internet service works. There are two types of Internet authentication. PPPoE and DHCP. You should know this first.
If you do, for PPPoE, you should be given a user name and password that should be set to the modem provided by your ISP(Internet Service Provider). You have to set your modem to bridge mode and set all the router to PPPoE then enter your user name and password.
If your Internet service authentication is a DHCP, you still have to set the modem to bridge mode (provided by ISP). Then set your router setting to DHCP. Reboot both your devices and you should be able to connect.
Hope that helps.
Thanks.
-jash
Apr 27, 2011 | Linksys Wireless-G WRT54G Router
I have samsung s5620 cell and i want to connect it to bsnl broadband wifi
you need to set ur router in PPPOE mode, then put the username and password that you put in the pppoe dialer into the router's PPPOE user name and password screen.. uncheck Dial on Demand/ Dial if needed box (if there)
thats it.. connect to as many as wifi enable devices u want
Jan 08, 2011 | Samsung S5620 Cell Phone
Wat is my PPPoE user name and passeord?
Hi It is the connection type of your internet service provider. If your internet depends on user and password then it needs pppoe . for that you need to configure router in pppoe mode but you can also create pppoe connection on your computer so just need to enter user and password of ppoe on computer then you can use internet on that computer. Let me know if you need further assistance.Thanks for using FixYa.
Nov 17, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
What is routed ppp and bridged?
Well,
PPPoE, is nothing but Point to Point over Ethernet.. which is your normal windows OS connectiod and the bridged mode is the mode in which the routers are set. In this mode, the router will authenticate with the uid and the passwrod, and not the modem. got it??
was i helpful?
Nov 19, 2008 | Computers & Internet
How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Dec 20, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
I have a linkys router model nr041
check if your router is configured for a pppoe mode, if not config it to pppoe mode, then you would be able to share internet, i suppose your internet service might be from dsl..
click here To setup your router..
Dec 17, 2007 | Linksys (NR041) Router
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
NetGear WGR614 Wireless Router Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
