that error relates to the fuser section of the machine. It can be a number of things, and is a failure of a heating component. I recommend professional service.
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter that is not included in your manual Go into service mode by depressing the additional function key, then 2
& 8 at the same time, then aditionall function key. Select copier,
then at the top far left side select counter. I blieve the counter is
under MISC as waste toner. Select waste toner, depress the " C " buton
on the keypad and it should reset to all 0's
You will need a program called 'Network Scangear' installed on your pcs and then search for scanners and discover the ir 5570. Then you can insert pic from scanner (your machine) from ny program. This is pull scanning though - you have to turn scanner on and leave document in the feeder- go back to your desk and 'insert from scanner' into your document that way. Nobody can use the machine for copying whilst you are doing this.
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server 7xx cannot connect ... 8xx could connect, but error... 801 bad user/pw or firewall 802 user/permissions 899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
