Question about Intel Motherboard
My dell laptop inspiron 1525, is just about 2 years old. About 4 weeks ago, I turned it on, and not lights came on, although the green light on the adapter was on. I was told by a technical assistant at Dell, to replace the adapter and battery. I now have a new adapter and battery, and I get the same results, no lights come on on the laptop. Could you please help me.
  • 526 Answers
First, I would try to return the battery and adapter, call your credit card company.
If anything, you would have a problem with the AC adapter and not both. If the battery was dead, the AC would still work. So at most, you should have just purchased an AC unit. However, because there was a green light, you were still getting power.
Take out the Hard drive and any removable hardware just to make sure they are not causing a short in the system.
If you do not see any display lights on your notebook when it is plugged in, then you have a problem with the Main Board. The whole unit will need to be taken apart and replaced with a new board. Main Boards usually run at a minimum of $180.00 on exchange plus labor.
My suggestion is to contact dell and ask them what it would cost for a repair or an upgrade. If you send the unit in, take out the Hard Drive to keep your data.
Thanks Adi
Please respond if you have more questions.
Posted on May 11, 2010
I have a Dell inspirion 1525 which is less than 2 years old however it will not power up, there are no lights on the laptop and no power going in. The charger has a green light on when plugged in but...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 23, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Dell inspiron 1525 won't turn on
Try to take out the battery and just use the adapter to power it on,
If your done with that then try just using the battery to turn it on, if it still won't give a single light.
If you can borrow an ac adapter for that laptop try it ,
If it still doesn't work. You'll need to replace the motherboard. Just make sure the ac adapter your gonna use is working good.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 won't turn on. Get a green light and that it.
remove the battery then put the charger.. then turn on, if the same problem... check the power button...
Jul 04, 2009 | Dell Inspiron 1525 Notebook
check the dc power jack connector, open the board. but if under warranty don't open it, bring to warranty..
Jun 05, 2009 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 won't charge
The battery has most likely been "Over charged". Most rechargeable batteries can only be charged around 500-1000 times depending on the brand of your computer. I would recommend buying a new one.
May 30, 2009 | Dell Inspiron 1525 Laptop
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
